Message 1 of 1
Create DXF from Selected Drawing Views?
06:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings,
I came across a code (see below) to export an inventor drawing to a DXF file, and it works great for what it is, but I was wondering if it's at all possible to take this code (or if there's another code that works better) and apply it to individual drawing views?
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 12316 StartFragment: 314 EndFragment: 12284 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'query user question = MessageBox.Show("is a .DXF Export Required", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) 'set condition based on answer If question = vbYes Then ' Get the DXF translator Add-In. path_and_nameDXF = ThisDoc.PathAndFileName(False) Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "W:\ENG34_TED\Inventor Research\Invengers Research" oOptions.Value("Export_Acad_IniFile") = strIniFile End If oDataMedium.FileName = path_and_nameDXF & ".dxf" Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If
