maybe this is some help to you:
' Lots of variable that can be set:
Dim startPositionX = 0
Dim positionY = 0
Dim viewOrientationType As ViewOrientationTypeEnum = ViewOrientationTypeEnum.kFrontViewOrientation
Dim drawingViewStyle As DrawingViewStyleEnum = DrawingViewStyleEnum.kShadedDrawingViewStyle
Dim scale = 1.0
If (ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject) Then
MsgBox("This only works if you opend a drawing document")
Return
End If
Dim oTr = ThisApplication.TransientGeometry
Dim dialog As Inventor.FileDialog
ThisApplication.CreateFileDialog(dialog)
dialog.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
dialog.FilterIndex = 1
dialog.ShowOpen()
Dim modelDoc = ThisApplication.Documents.Open(dialog.FileName)
Dim modelDef = modelDoc.ComponentDefinition
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim x = startPositionX
For Each item As DesignViewRepresentation In modelDef.RepresentationsManager.DesignViewRepresentations
Dim nameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
nameValueMap.Add("DesignViewRepresentation", item.Name)
Dim p As Point2d = oTr.CreatePoint2d(x, positionY)
Dim view As DrawingView = sheet.DrawingViews.AddBaseView(modelDoc, p, scale,
viewOrientationType, drawingViewStyle,,, nameValueMap)
x = x + view.Width
Next
Jelte de Jong
Blog: hjalte.nl - github.com
