Create Custom iProperties & Parameters for Sub-Assemblies
Preston_Reed
Preston_Reed
Hello, I am trying to create a rule that will create custom iProperties & User Parameters for sub-assemblies & their piece parts.  The intention is to make the custom iProperties as they fill in title block info.  Also I am working on making a tool that will replace design assistant for design copy type projects.  I have the majority of it working besides being able to create custom iProperties and User Parameters for the sub-assemblies and their piece parts.  Any help would be appreatiated.  Here is an example of what I was trying to do, this doesn't do anything, I went about it through oOccurences too but that wouldn't work, I don't think its allowing me to access ComponentDefinition though Occurences.
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    ' Get all of the referenced documents.
    Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
    ' Iterate through the list of documents.
    For Each oRefDoc As Document In oRefDocs
		'Skipping any purchased or mfg parts / any parts that are not accessable
		If oRefDoc.IsModifiable() = True AndAlso oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			oSubAsmParameter = oRefDoc.ComponentDefinition.Parameters.UserParameters
			'Creating sub-assembly user parameters
			oParameter = oSubAsmParameter.AddByValue("CUSTOMER NAME-1", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("CUSTOMER PO#", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("END USER-1", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("PARENT PRODUCT#", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("PROJECT#", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("SO#", "", UnitsTypeEnum.kTextUnits)
			oParameter = oSubAsmParameter.AddByValue("WORK ORDER#", "", UnitsTypeEnum.kTextUnits)
		Else
	Next
Frederick_Law
This part of old VBA code to get Properties from active assembly and copy them to all childs.
The important part is recursive processAllSubFiles.
Private Sub SetCmdBtn_Click()
'Dim Temp(1, 4)
'Temp(0, 0) = TitleBox
'Temp(0, 1) = CompanyBox
'Temp(0, 2) = RevBox
'Temp(0, 3) = ProjectBox
'HistoryList.List() = Temp
'HistoryList.ListIndex = 0
Dim oDoc As Inventor.Document
Dim oPropsets As PropertySets
Dim oPropSet As PropertySet
Dim oRefFiles As DocumentsEnumerator
Dim oRefFile As Document
Dim iLeafNodes As Long
Dim iSubAssemblies As Long
Set oDoc = ThisApplication.ActiveDocument
Set oRefFile = oDoc
If oRefFile.IsModifiable Then
  Set oPropsets = oRefFile.PropertySets
  Set oPropSet = oPropsets.Item("Design Tracking Properties")
  If (oPropSet.Item("Project").value <> "Common") _
     And (oPropSet.Item("Project").value <> "Purchase") _
     And (oPropSet.Item("Project").value <> "Hardware") Then
    Set oPropSet = oPropsets.Item("Summary Information")
    oPropSet.Item("Title").value = TitleBox
    oPropSet.Item("Revision Number").value = RevBox
    oPropSet.Item("Author").value = AuthorBox
    Set oPropSet = oPropsets.Item("Document Summary Information")
    oPropSet.Item("Company").value = CompanyBox
    oPropSet.Item("Project").value = ProjectBox
    oPropSet.Item("Designer").value = DesignerBox
' Get all occurrences from component definition for Assembly document
Set oRefFiles = oDoc.ReferencedDocuments
processAllSubFiles oRefFiles
End Sub
Private Sub processAllSubFiles(ByVal oRefFiles As DocumentsEnumerator)
For Each oRefFile In oRefFiles
    If oRefFile.ReferencedFiles.Count > 0 Then
        processAllSubFiles oRefFile.ReferencedFiles
Next
End Sub
Frederick_Law
Partial VB.Net, different recursive:
  Private Sub BtSet_Click(sender As Object, e As EventArgs) Handles btSet.Click
    SetProperties(OApp.ActiveDocument)
  End Sub
  Private Sub SetProperties(oDoc As Document)
    Dim MCValue As String
    Dim EtchValue As String
    If oDoc.IsModifiable Then
      oPropsets = oDoc.PropertySets
      oPropset = oPropsets.Item("Summary Information")
      If cbTitle.Checked Then
        oPropset.Item("Title").Value = PropCopy.StandardAddInServer.Title
      If cbRev.Checked Then
        oPropset.Item("Revision Number").Value = PropCopy.StandardAddInServer.Rev
      If cbAuthor.Checked Then
        oPropset.Item("Author").Value = PropCopy.StandardAddInServer.Author
      oPropset = oPropsets.Item("Document Summary Information")
      If cbCompany.Checked Then
        oPropset.Item("Company").Value = PropCopy.StandardAddInServer.Company
      oPropset = oPropsets.Item("Design Tracking Properties")
      If cbProject.Checked Then
        oPropset.Item("Project").Value = PropCopy.StandardAddInServer.Project
      If cbDesigner.Checked Then
        oPropset.Item("Designer").Value = PropCopy.StandardAddInServer.Designer
      oPropset = oPropsets.Item("User Defined Properties")
      If cbFinish.Checked Then
        Try
          oPropset.Item("Finish").Value = PropCopy.StandardAddInServer.Finish
        Catch
          oPropset.Add(PropCopy.StandardAddInServer.Finish, "Finish")
        End Try
      If cbHardness.Checked Then
        Try
          oPropset.Item("Hardness").Value = PropCopy.StandardAddInServer.Hardness
        Catch
          oPropset.Add(PropCopy.StandardAddInServer.Hardness, "Hardness")
        End Try
      If cbThickness.Checked Then
        Try
          oPropset.Item("Thickness").Value = PropCopy.StandardAddInServer.Thickness
        Catch
          oPropset.Add(PropCopy.StandardAddInServer.Thickness, "Thickness")
        End Try
      If cbCode.Checked Then
        Try
          oPropset.Item("CODE").Value = PropCopy.StandardAddInServer.Code
        Catch
          oPropset.Add(PropCopy.StandardAddInServer.Code, "CODE")
        End Try
      If cbMaterialCert.Checked Then
        If MCYesButton.Checked Then
          MCValue = "MTR and Heat Number Required"
        Else
          MCValue = ""
        Try
          oPropset.Item("Material Cert Required").Value = MCValue
        Catch
          oPropset.Add(MCValue, "Material Cert Required")
        End Try
      If cbEtch.Checked Then
        If EtchYesButton.Checked Then
          EtchValue = "Etching"
        Else
          EtchValue = ""
        Try
          oPropset.Item("Etch").Value = EtchValue
        Catch
          oPropset.Add(EtchValue, "Etch")
        End Try
    Close()
  End Sub
  Private Sub BtSetAll_Click(sender As Object, e As EventArgs) Handles btSetAll.Click
    oDoc = OApp.ActiveDocument
    SetProperties(oDoc)
    For Each oRefFiles In oDoc.AllReferencedDocuments
      If oRefFiles.IsModifiable Then
        SetProperties(oRefFiles)
    Next
    Close()
  End Sub
Preston_Reed
Thanks for the help, cant get any of this to work though
Preston_Reed
Solved for the most part
		' Skipping any purchased or mfg parts / any parts that are not accessable
			Try
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("CUSTOMER NAME-1").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("CUSTOMER PO#").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("END USER-1").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("PARENT PRODUCT#").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("PROJECT#").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("SO#").Value = ""
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("WORK ORDER#").Value = ""
			Catch
		   		oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "CUSTOMER NAME-1")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "CUSTOMER PO#")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "END USER-1")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "PARENT PRODUCT#")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "PROJECT#")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "SO#")
				oRefDoc.PropertySets("Inventor User Defined Properties").Add("", "WORK ORDER#")
		    End Try
		Else
	Next
