Create constraint with "value" ( Parameter and/or Math Syntax, etc )
Crstiano
Crstiano
Components.Add("MyNewComponent", MyFile.ipt)
Constraints.AddFlush("Flush:1", "MyNewComponent", "XY Plane", "", "XY Plane", Distance)
There are a function that simulate the same routine that the inventor does a textbox for enter distance value ?
Or verify is there are parameter, or is a math syntax, or both..
Or someone writed all these checks and can do share this code?
I accept suggestions.
Thanks in advance
Cristiano Oliveira
ConsultCAD.com
WCrihfield
Are you asking about this function?
Dim oDistance As Double = InputBox("Enter Distance.")
Wesley Crihfield
(Not an Autodesk Employee)
Crstiano
Maybe I'm created a tempest in a teapot...
The question is about: How to create a textbox at form equal (with all features includes) like the autodesk inventor ?
example: the offset at constraint, where its check if the value is: parameter , a syntax math, or if you specify which units etc...
Cristiano Oliveira
ConsultCAD.com
JhoelForshav
Hi @Crstiano
What you write in the textbox for distance is actually a parameter expression.
You can use UnitsOfMeasure to evaluate if an expression is valid. See iLogic code below. In the example I let the user type in an expression. It can contain names of parameters in the document, math signs etc. If its a valid length the code will return the calculated length in a msgbox, else it'll tell you the expression isn't valid.
Dim oUOM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim otext As String = InputBox("Length expression: ", "write expression")
Dim oValidEx As Boolean
Try
oValidEx = oUOM.CompatibleUnits(otext, UnitsTypeEnum.kDefaultDisplayLengthUnits, "1", UnitsTypeEnum.kDefaultDisplayLengthUnits)
Catch
oValidEx = False
End Try
If oValidEx
	Dim oValue As Double = oUOM.GetValueFromExpression(otext, UnitsTypeEnum.kDefaultDisplayLengthUnits)
	Dim oValueString As String = oUOM.GetStringFromValue(oValue, UnitsTypeEnum.kDefaultDisplayLengthUnits)
	MsgBox("Return length: " & oValueString)
Else
	MsgBox("Not valid length expression")
End If
Check page 21 here for the textbox you describe 🙂
https://modthemachine.typepad.com/files/ipropertiesandparameters.pdf
