Dear Wesley,
The rule you shared works beautifully, thank you very much. So far there is only one problem however and that is that one of the part in my testcase does not have the derived solid, it also occured to me that all the other parts have a small green arrow in the derived part part browser vbut this one does not. It should be added that this part is created using a mirror + "New Solid" instead of an Extrude or Face feature. Please find attached a screenshot of the derived part browser and the modded code.
And here is the Code:
' Folder to place the new assembly and parts
Dim path As String: path = ThisDoc.Path & "/"
' Use the docs first 9 characters as prefix for the new filenames
Dim prefix As String: prefix = Left(ThisDoc.FileName(False), 9)
Dim doc As PartDocument
doc = ThisApplication.ActiveDocument
' Create new assembly
Dim assy As AssemblyDocument
assy = ThisApplication.Documents.Add(kAssemblyDocumentObject)
Dim sBody As SurfaceBody
For Each sBody In doc.ComponentDefinition.SurfaceBodies
' Create a part for each surfacebody
Dim prt As PartDocument
prt = ThisApplication.Documents.Add(kPartDocumentObject)
Dim dpcs As DerivedPartComponents
dpcs = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim dpd As DerivedPartUniformScaleDef
dpd = dpcs.CreateUniformScaleDef(doc.FullDocumentName)
' Exclude the other solid bodies
Dim dpe As DerivedPartEntity
For Each dpe In dpd.Solids
If Not dpe.ReferencedEntity Is sBody Then
dpe.IncludeEntity = False
End If
Next
For Each dpe In dpd.Sketches
Next
Call dpcs.Add(dpd)
' Save using prefix and solid body's name
Call prt.SaveAs(path + prefix + sBody.Name + ".ipt", False)
' Place an instance of it inside the assembly
Dim mx As Matrix
mx = ThisApplication.TransientGeometry.CreateMatrix()
Call assy.ComponentDefinition.Occurrences.AddByComponentDefinition(prt.ComponentDefinition, mx)
' Close the part
Call prt.Close
Next
' Save the assembly
Call assy.SaveAs(path + prefix + "001" + ".iam", False)
Many thanks so far, I hope this final mystery can be solved.
