02:46 AM
- Mute
- Permalink
- Report
I'm trying to pattern a component using another components axis in an assembly:
Public Sub Pattern() Dim oADoc As AssemblyDocument = InvApp.ActiveEditDocument Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition Dim InvPart1 As ComponentOccurrence = oADef.Occurrences.Item(1) Dim InvPart2 As ComponentOccurrence = oADef.Occurrences.Item(2) Dim oAxis As WorkAxis = InvPart1.Definition.workaxes(1) MsgBox("Part1 : " & InvPart1.Name & vbCr & "Part2 : " & InvPart2.Name & vbCr & "Axis : " & oAxis.Name) Dim oOccPatterns As OccurrencePatterns = oADef.OccurrencePatterns Call oOccPatterns.AddCircularPattern(InvPart2, oAxis, True, "45 deg", 8) End Sub
The message box proves that it is successfully finding the two compoents and the X Axis of the first component.
It keeps falling over on the last line, when trying to create the pattern, I've tried creating a workaxisproxy but found this made no difference.
attached is the assembly file I've been trying it out on
Any help with this would be great.
