Create an ilogic rule for round up length
eladm
Message 1 of 24
eladm
Hi All
I need an ilogic rule for  tube and pipe length
for example:
for each pipe when the length (QTY column ) is between 0-4.99 m another column (Item QTY for example) the value will be : 5m .  when the length between 5-9.99 m the value will be 10m , when the length between 10-14.99 m the value will be 15m . If the length will be at inch can it convert to m , and than change the other column value ?
Regards
Replies (23)
Message 21 of 24
Stakin
please paste the line 7
Message 22 of 24
eladm
THE ERROR IS ALSO HAPPENING WHEN THERE ONLY 1 PART LIST IN THE DRAWING
Message 23 of 24
Stakin
maybe you copy the code before i modify
Message 24 of 24
Stakin
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oUm As UnitsOfMeasure = oDrawDoc.UnitsOfMeasure
Dim oSPL As Double = 5000 'oSingle section pipe length(‘mm’)
Dim oILP As Double = 5'Installation loss percentage(0~100)
For Each oSheet As Sheet In oDrawDoc.Sheets
For Each oPartslist As PartsList In oSheet.PartsLists
	For Each row As PartsListRow  In oPartslist.PartsListRows
        Row.Item("QTY").Static = False
		Dim  oValue As Double
		Try
			oValue = CDbl(Row.Item("QTY").Value)
		Catch
			oValue = oUm.GetValueFromExpression(Row.Item("QTY").Value, UnitsTypeEnum.kInchLengthUnits)
			oValue=Math.Ceiling(oValue*(10+oILP/10)/oSPL)
		End Try
		Row.Item("QTY").Value = CStr(oValue)
    Next
Next
Next
Just try this.
