Hello everybody,
My problem same that situation, i think i can solve my problem. But something wrong.
I have a ACAD file, i imported to inventor, projected geometry, then I want each closed profile is one solid body.
But After debuged, the count of profile is 4. But I can not delete profile item number 3, i just want extrude number 4.
Could you help me about this. Thank you very much.
This is my picture profile and my code.
Private Sub btn_testcode_Click(sender As Object, e As EventArgs) Handles btn_testcode.Click
Dim oDoc As PartDocument
oDoc = oinv.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oinv.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject, SystemOfMeasureEnum.kMetricSystemOfMeasure, DraftingStandardEnum.kISO_DraftingStandard))
Dim ocompdef As ComponentDefinition = oDoc.ComponentDefinition
Dim otransi As TransientGeometry = oinv.TransientGeometry
Dim opartdef As PartComponentDefinition = oDoc.ComponentDefinition
'Dim osketch1 As PlanarSketch = opartdef.Sketches.Add(oDoc.ComponentDefinition.WorkPlanes.Item(2))
'import dwg profile random
Dim oRefComponents_2400 As ReferenceComponents
oRefComponents_2400 = ocompdef.ReferenceComponents
' Create a ImportedComponentDefinition based on an AutoCAD file.
Dim oImportedCompDef_2400 As ImportedComponentDefinition
oImportedCompDef_2400 = oRefComponents_2400.ImportedComponents.CreateDefinition(oFileDlg.FileName)
Dim oImportedDWGDef_2400 As ImportedDWGComponentDefinition
If oImportedCompDef_2400.Type = ObjectTypeEnum.kImportedDWGComponentDefinitionObject Then
oImportedDWGDef_2400 = oImportedCompDef_2400
Else
End
End If
Dim oImportedComponent_2400 As ImportedComponent
oImportedComponent_2400 = oRefComponents_2400.ImportedComponents.Add(oImportedDWGDef_2400)
Dim oImportedDWGComponent_2400 As ImportedDWGComponent
Dim oSk_2400 As PlanarSketch
If oImportedComponent_2400.Type = ObjectTypeEnum.kImportedDWGComponentObject Then
oImportedDWGComponent_2400 = oImportedComponent_2400
oSk_2400 = ocompdef.Sketches.Add(opartdef.WorkPlanes.Item(3))
' oSk = ocompdef.Sketches.Add(oworkplane1)
' Get the DWGBlockDefinition for model space.
Dim oDWGModelSpaceDef As DWGBlockDefinition
oDWGModelSpaceDef = oImportedDWGComponent_2400.ModelSpaceDefinition
' Project DWG entities to planar sketch.
Dim oDWGEntity As DWGEntity
For Each oDWGEntity In oDWGModelSpaceDef.Entities
Call oSk_2400.AddByProjectingEntity(oDWGEntity)
Next
oinv.ActiveView.GoHome()
oImportedDWGComponent_2400.Visible = False
oSk_2400.Visible = False
Dim oprofile2 As Profile = oSk_2400.Profiles.AddForSolid()
Dim iprocount As Integer
iprocount = oprofile2.Count()
Dim oprofile3 As Profile = oSk_2400.Profiles.AddForSolid
oprofile3.Item(1).Delete()
oprofile3.Item(2).Delete()
oprofile3.Item(3).Delete()
Dim oextrudef2 As ExtrudeDefinition = opartdef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oprofile3,
PartFeatureOperationEnum.kNewBodyOperation)
oextrudef2.SetDistanceExtent(340, PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
Dim oextrude2 As ExtrudeFeature = opartdef.Features.ExtrudeFeatures.Add(oextrudef2)
End If
End Sub
