Create a Point from Vertex or Object in Assembly Enviroment
florian_wenzel
Message 1 of 12
florian_wenzel
Inventor 2022
API Visual Studio VB.NET
i try to insert a Part in Assembly.
I want to Put the Part in a Position, which is defined with a SelectingPoint.
The Goal is to Set the Part in a StartPoint from a Projecting Curve.
Actualy, i want to Create a New Part, so that the Origin Point will be in Position of Start Point from Projecting Curve.
I got Error, when i select the Point.
This is the Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Module CommandFunctionButton_01
    Public Sub CommandFunctionfweButton_01()
        Dim oAsmDoc As AssemblyDocument = g_inventorApplication.ActiveDocument
        Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oPointOriginSet As Vertex = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Point")
        Dim oPointOrigin As Point
        oPointOrigin = oPointOriginSet.Point
        Dim oXAxis As Vector = oTG.CreateVector(1, 0, 0)
        Dim oYAxis As Vector = oTG.CreateVector(0, 1, 0)
        Dim oZAxis As Vector = oTG.CreateVector(0, 0, 1)
        Dim oMatrix As Matrix = oTG.CreateMatrix
        Call oMatrix.GetCoordinateSystem(oPointOrigin, oXAxis, oYAxis, oZAxis)
        Dim oOcc As ComponentOccurrence = oAsmCompDef.Occurrences.Add("C:\InventorAPI\001\CAD\3D\Part_02.ipt", oMatrix)
    End Sub
End Module
Where is the Problem?
I was Trying o create the Point with, Object or Vertex, but always get a Error.
I dont want to write the Coordinate, i want to Select the Point.
Thanks for any Suggestion
Replies (11)
Message 2 of 12
WCrihfield
Hi @florian_wenzel.  When you select a Vertex within the context of an assembly, the selected object will be a VertexProxy, instead of a regular Vertex.  Then later, after you create a new Matrix, it looks like you may be using the wrong method for specifying its coordinate system.  You are using the Get method, when it seems you should be using the Set method.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 12
florian_wenzel
Still Error
Message 4 of 12
WCrihfield
Well, I can't read the error message, because it is in a language I am not fluent in, but I can tell it is having trouble with a Type mismatch.  When I use the Pick method, I usually do not declare the variable's Type ahead of time, then on the next line, check if anything was picked, then check the Type of the picked object, and if the Type is not what I am expecting, I do not progress forward.  So, you could create a generic Object Type variable to store the picked object to at first, then check what you picked on the next line, before continuing.  Is it possible you are picking a WorkPoint instead of a Vertex/VertexProxy?
Wesley Crihfield
Message 5 of 12
florian_wenzel
actually the idea is, to use or Select the Start points from a Curve in a Assembly Sketch,
and with this Position Create a New Part, and then continue with a Creating 3D Model.
The Error:
System.InvalidCastException: "The COM object of type 'System.__ComObject' cannot be cast to the interface type 'Inventor.Vertex'. This operation could not be performed because the QueryInterface call to the COM component for the interface with The IID "{5DF8608F-6B16-11D3-B794-0060B0F159EF}" could not be performed due to the following error: Interface not supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE))."
Message 6 of 12
florian_wenzel
is possible to Get the Coordinate (x,y,z) from a Selecting Point, Vertex or whatEver, but in Assemby Enviroment?
Then use this to Create a Point with this Coordinate
Message 7 of 12
WCrihfield
OK. This information adds more possible object types that you may be selecting, depending on the context that the sketch was generated within (SketchPoint, SketchPoint3D, SketchPointProxy, SketchPoint3DProxy).  And I don't know if SketchSplineHandle type objects would be select-able using that selection filter or not, but there are 4 variations of those too.  If the sketch and/or its contents were created directly within the main assembly, they may not be proxy objects.  Ultimately you kind of need to know which type of object you are selecting, to be able to use the proper properties of that object, such as a transient Point object.  I suppose you could create a Point type variable with no value, then use a Try...Catch block with several Catch sections within it in an attempt to extract the Point from the various possible object types, then check whether your previously created variable was given a value afterwards.  Or use a series of If...ElseIf...Else...End If type block, in which you use the TypeOf operator to check its Type, then extract the Point in the necessary way for the Type.  It's a hard one to diagnose remotely, without some trial/error testing.
Wesley Crihfield
Message 8 of 12
WCrihfield
There is a way to extract mouse pointer location type information when working with the MouseEvents object's available Events, but that data is most likely not going to be accurate enough, because of the 2D nature of your model area view pane.  Plus using those Events are not as intuitive or easy to use as you are likely expecting.
Wesley Crihfield
Message 9 of 12
WCrihfield
Here is a quickie little utility iLogic rule you can use to quickly identify what type of object you are selecting within the context of an assembly.
Sub Main
	While True
		oPt = PickPoint
		If IsNothing(oPt) Then Exit While
	End While
End Sub
Function PickPoint(Optional oPrompt As String = vbNullString) As Object
	If String.IsNullOrEmpty(oPrompt) Then oPrompt = "Pick a Point"
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, oPrompt)
	If IsNothing(oObj) Then Return Nothing
	MsgBox("Picked Point Object TypeName(oObj) = " & TypeName(oObj), , "")
	Return oObj
End Function
Wesley Crihfield
Message 10 of 12
florian_wenzel
i was checking all 4 variations (SketchPointSketchPoint3DSketchPointProxySketchPoint3DProxy)
Unfortunately, neither works.
"SketchPoint"
Dim oPointOriginSet As SketchPoint = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Point")
oPointOrigin = oPointOriginSet.Geometry3d
"SketchPoint3D"
Dim oPointOriginSet As SketchPoint3D = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Point")
"SketchPointProxy"
Dim oPointOriginSet As SketchPointProxy = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Point")
"SketchPoint3DProxy"
Dim oPointOriginSet As SketchPoint3DProxy = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Point")
The Sketch in Assembly was Creating with Mouse normaly, Native. Simple Projecting the Outside Edges on A Offset WorkPlane. As a Sketch 2d.
I Think in a Assembly you are able to Create only 2dSketch or ?
Message 11 of 12
florian_wenzel
Ilogic info:
So, it shows that this is SketchPoint, not WorkPoint, and not VertexProxy.
Vertex Proxy, only on 3D Model from Assembly, or other Models
Message 12 of 12
florian_wenzel
Ok its Working
Imports Inventor
        Call oMatrix.SetCoordinateSystem(oPointOrigin, oXAxis, oYAxis, oZAxis)
    End Sub
End Module
