@Guthery1
If you look at what actually happens when you create a plane by line, plane and angle in an assembly, it adds a plane and then it adds a mate constraint to the line and an angle constraint to the plane. You can write your own function to mimic this behaviour.
See example below:
Sub Main
Dim yAxis As WorkAxis = ThisDoc.Document.ComponentDefinition.WorkAxes("Y Axis")
Dim YZPlane As WorkPlane = ThisDoc.Document.ComponentDefinition.WorkPlanes("YZ Plane")
Dim oWPlane As WorkPlane = AddPlaneByLinePlaneAndAngle(yAxis, YZPlane, 45)
oWPlane.Name = "Plane_Name"
End Sub
Function AddPlaneByLinePlaneAndAngle(_line As Object, _plane As Object, _angle As Double) As WorkPlane
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim oOriginPnt As Point
Dim oXaxis As UnitVector
Dim oYaxis As UnitVector
oOriginPnt = ThisApplication.TransientGeometry.CreatePoint(0#, 0#, 0#)
oXaxis = ThisApplication.TransientGeometry.CreateUnitVector(1#, 0#, 0#)
oYaxis = ThisApplication.TransientGeometry.CreateUnitVector(0#, 1#, 0#)
Dim oPlane As WorkPlane = oDef.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
oPlane.AutoResize = True
oDef.Constraints.AddMateConstraint(_line, oPlane, 0, InferredTypeEnum.kInferredLine, InferredTypeEnum.kNoInference)
Dim oAngleConstraint As AngleConstraint = oDef.Constraints.AddAngleConstraint(_plane, oPlane, 0, AngleConstraintSolutionTypeEnum.kDirectedSolution)
oAngleConstraint.Angle.Expression = _angle.ToString
oPlane.AutoResize = False
ThisDoc.Document.Update
Return oPlane
End Function
