Create a list of predefined instance properties to preselected items using i logic
mark_brennan2
mark_brennan2
Hi, can anyone help?
I have a list of instance properties that I need to add to components within an assembly.
At the moment I have to type them in each time which is inefficient.  The properties have a unique value to be added manually.  Is this possible using i logic?
The properties are listed below.
Plant_No
Room_No
System
System_Group
Thanks for any help
C_Haines_ENG
Maybe something like this would work? Its not the most elegant solution ever, but it does work. You also don't have to preselect the components, but if you would like to have that as a feature I can tweak the code pretty easily.
Sub Main
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oNames As New List(Of String)
	oNames.AddRange({"Plant_No", "Room_No", "System", "System Group" })
	Do
		Dim oComp As ComponentOccurrence = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "Select Component")
		If oComp Is Nothing Then Exit Sub
		Dim oCustomProps As PropertySet = oComp.Definition.Document.PropertySets("Inventor User Defined Properties")
		For Each oName As String In oNames
			Try
				oCustomProps(oName).Value = oCustomProps(oName).Value
			Catch
				oCustomProps.Add("", oName)
			End Try
				Dim oAsk As String = InputBox("Current Component : " & oComp.Name & vbLf & vbLf _
				& "Enter value for : " & oName, "iProp Customizer", oCustomProps(oName).Value)
				If oAsk = "" Then Exit Sub
				oCustomProps(oName).Value = oAsk
		Next
	Loop
End Sub
mark_brennan2
Thanks for your help.
I have run the rule and it works well.
could this ilogic be made to create instance properties instead of iproperties.
Regards
Mark
C_Haines_ENG
Ah, I misunderstood. To be honest I had no clue Instance Properties were a thing until your post! This new code should work:
Sub Main
	Do
		'Dim oCustomProps As PropertySet = oComp.Definition.Document.PropertySets("Inventor User Defined Properties")
			Try
				iProperties.InstanceValue(oComp.Name, oName) = iProperties.InstanceValue(oComp.Name, oName)
			Catch
				iProperties.InstanceValue(oComp.Name, oName) = ""
			End Try
				& "Enter value for : " & oName, "iProp Customizer", iProperties.InstanceValue(oComp.Name, oName))
				iProperties.InstanceValue(oComp.Name, oName) = oAsk
		Next
	Loop
End Sub
mark_brennan2
That worked perfectly.  Thanks very much for your time and effort.
Regards
Mark
