create a centerline by two points
breinkemeyer
breinkemeyer
Trying to add a centerline to a drawing view but it keeps failing at the centerlines.add method.  All I get is an ambiguous error message.  What am i missing?
DrawingDocument oDoc = (DrawingDocument)oInventorApp.ActiveDocument;
Sheet oSheet = oDoc.ActiveSheet;
DrawingView oView = oSheet.DrawingViews[1];
Centerlines oLines = oSheet.Centerlines;
DrawingSketch oSketch = oView.Sketches.Add();
SketchPoints oPoints = oSketch.SketchPoints;
oSketch.Edit();
SketchPoint pnt1 = oPoints.Add(oITransGeo.CreatePoint2d(0, 0), false);
SketchPoint pnt2 = oPoints.Add(oITransGeo.CreatePoint2d(216 * 2.54, 0), false);
oSketch.ExitEdit();
GeometryIntent oInt1 = oSheet.CreateGeometryIntent(pnt1);
GeometryIntent oInt2 = oSheet.CreateGeometryIntent(pnt2);
ObjectCollection oCollection = oInventorApp.TransientObjects.CreateObjectCollection();
oCollection.Add(oInt1);
oCollection.Add(oInt2);
Centerline line = oLines.Add(oCollection);
A.Acheson
Hi @breinkemeyer
It might be the declaration of sketchpoint instead of offering point2d directly into  geometry intent.
See intent help page here
Regards
Alan
WCrihfield
Just another odd thought that comes to mind, but it may be a stretch of the imagination.  Since this is a drawing sketch being created within a drawing view, you may have to translate the two transient Point2d objects from 'sheet space' to 'view space' and/or to 'sketch space'.
DrawingSketch.SheetToSketchSpace
DrawingView.SheetToDrawingViewSpace
Wesley Crihfield
(Not an Autodesk Employee)
breinkemeyer
So this may not be the best way to do it, but I ended up adding two workpoints to the assembly then translated them using modeltosheetspace and adding a sketchline between those points.  Then I changed the linetype to chained.
A.Acheson
Hi @breinkemeyer
Yes that would be a good way to tie a centerline to the model. You can also project a curve into the sketch and constrain the line to that curve.
Here is a quick sample in VB.NET of just adding a sketchline and changing layer to Centerline.
Dim drawView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view")
Dim drawDoc As DrawingDocument= ThisApplication.ActiveDocument
Dim sketch1 As DrawingSketch = drawView.Sketches.Add
sketch1.Edit
Dim startPt As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
startPt = drawView.SheetToDrawingViewSpace(startPt)
Dim endPt As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(216*2.54,0)
endPt = drawView.SheetToDrawingViewSpace(endPt)
Dim oLine As SketchLine = sketch1.SketchLines.AddByTwoPoints(startPt, endPt)
Dim layers As LayersEnumerator = drawDoc.StylesManager.Layers
oLine.Layer = layers.Item("Centerline (ANSI)")
sketch1.ExitEdit
This isn't tied to any specific geometry, the centerline is just of the sheet.
Regards
Alan
JBerns
This was the closest topic match I could find related to my two-point centerline creation issue.
I am trying to create a centerline through the bolt (a content center component). I tried retrieving the Work X AXis, but the line needed editing for layer, start position, and end position.
I would have to get info from the bolt to calculate those points.
Manually creating a centerline by picking two points gave the best initial result.
The challenge - I would need to get these "points" from the fastener in each view. Would need to factor view scale (I think).
Adding a work point or named entities to all the content center library components seems like a daunting task.
Is it possible to get the bolt points and create the centerline using iLogic? FYI - this is just one element in a pattern if that makes a difference.
I am not looking for code just yet - just checking if possible and any advice to get started. Sample model and drawing attached.
Thank you for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
