Creat a sketch on a new part
i use this code to creat a new part , and a new sketch.
But the sketch doesn(t work, i don't understand why.
someone can help me please?
Sub test()
'Créer une nouvelle piece SHOP
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    oTemplatesPath = oApp.DesignProjectManager.ActiveDesignProject.TemplatesPath
    oTemplateFile = "piece SHOP.ipt"
    oTemplate = oTemplatesPath & "\" & oTemplateFile
    Dim oPartDoc As PartDocument
    Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, oTemplate)
'Créer une esquisse
    ' Create a 2D sketch on the X-Y plane.
    Dim sketch1 As PlanarSketch
    Set sketch1 = oPartDoc.Sketches.Add(oPartDoc.WorkPlanes.Item(3))
    Dim tg As TransientGeometry
    Set tg = oApp.TransientGeometry
    ' Draw rectangles by center point.
    Call Sketch.SketchLines.AddAsTwoPointCenteredRectangle(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(8, 3))
End Sub
WCrihfield
Hi @Anonymous.  It looks like you were missing a 'link in the chain' within your lines of code.  You needed to add 'ComponentDefinition' in there between the Part and the Sketches, and between the Part and the WorkPlanes.  Then you also didn't include the '1' in the variable's name for the Sketch object at the start of the last line.  Here it the corrected code that worked in my test.:
Sub test()
'Créer une esquisse
    Set sketch1 = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes.Item(3))
    Call sketch1.SketchLines.AddAsTwoPointCenteredRectangle(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(8, 3))
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
