Crash on CurveEvaluator.GetStrokes and Edge.CalculateStrokes
Message 1 of 10
Hello there!
I seem to have a peculiar problem:
I'm trying to compute the intersections of several SurfaceBody instances with a plane and then convert the resulting edges of the intersection bodies to 2D approximations in the plane's local space.
The intersection part works fine. The only "issue" is that the TransientBRep.CreateIntersectionWithPlane(...) method throws an exception if there is no intersection between the body and the plane and those exceptions clutter my debug output, but that's not really a problem.
The problem comes up in the next step: Since I can't find a way to get a 2D projection on the plane of the 3D curves of the intersection's edges directly, I tried to get a linear approximation of each edge and project the points of this approximation onto my plane.
Sadly, getting the linear approximation of these edges seems to be nigh impossible. I tried three approaches:
a) Use the CalculateStrokes method of the edge directly:
foreach (Edge edge in intersectionBody.Edges)
    try
        int vertexCount, segmentCount;
        double[] vertexCoords = { };
        int[] vertexIndices = { };
        edge.CalculateStrokes(tolerance, out vertexCount, out segmentCount, out vertexCoords, out vertexIndices); // immediate crash
    catch (System.Exception ex)
b) Use the GetStrokes method of the edge's geometry's evaluator:
    try
        CurveEvaluator eval = edge.Geometry.Evaluator;
        double minParam, maxParam, length;
        eval.GetParamExtents(out minParam, out maxParam);
        int vertexCount;
        eval.GetStrokes(minParam, maxParam, tolerance, out vertexCount, out vertexCoords); // immediate crash
c) Use the TransientGeometry.CreatePolyline3dFromCurve method.
    try
        Polyline3d pl = tGeo.CreatePolyline3dFromCurve(edge.Geometry, tolerance); // throws an exception
Both a) and b) result in an immediate crash of Inventor with no way for me to catch the exception. c) throws an exception, meaning I can actually catch that one and keep Inventor from crashing immediately.
Since a) and b) crash immediately I can't tell if they would work for other edges in the body. c) doesn't work for any of the edges.
My current workaround is to use the CurveEvaluator to get a ridiculous number of points and filter those based on my tolerance. This is pretty inefficient and actually takes a lot longer than the intersection computation does, so it's not a real option in the long run.
Can anybody help me with this issue?
Replies (9)
Message 2 of 10
adam.nagy
Autodesk Support
Autodesk Support
So
does not work for any edge? Could you try initializing the arrays like this?
double[] vertexCoords = new double [] { };
int[] vertexIndices = new int[]{ };
Adam Nagy
Autodesk Platform Services
Message 3 of 10
klemen_zivkovic
How can I use ThisApplication.TransientGeometry.CreatePolyline3dFromCurve from edge object? Is that possible?
I am having hard time to translate from edges for elipticalarc to 3d points... Is there any shorter way to acomplish this?
I also tried with
Call oEdge.CalculateStrokes(oEdge.GetExistingStrokeTolerances(100,), 100, 100, vertexCoordinates, vertexIndices)
Bu this gives me only 2d points - Is it possible to get 3d points with
regards
Message 4 of 10
klemen_zivkovic
OK that's the way to do it:
Set pline = ThisApplication.TransientGeometry.CreatePolyline3dFromCurve(oEdge.Geometry, 0.01)
For l = 1 To pline.PointCount
Set p = pline.PointAtIndex(l)
Next l
Message 5 of 10
FRFR1426
On Inventor 2016 SP1, CurveEvaluator.GetStrokes fails on circle. Inventor immediately crash with an access violation in ASMKERN221.dll and the message: "Memory may have been left in an inconsistent state." It works for arc.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 6 of 10
FRFR1426
Here is a bit of VBA code to reproduce the crash:
Public Sub Crash()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to component definition of the active part.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oTransientBRep As TransientBRep
    Set oTransientBRep = ThisApplication.TransientBRep
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    Dim p As Point
    Set p = oTransGeom.CreatePoint(0, 0, 0.035)
    Dim n As Vector
    Set n = oTransGeom.CreateVector(0, 0, 1)
    Dim pl As Plane
    Set pl = oTransGeom.CreatePlane(p, n)
    Dim sb As SurfaceBody
    Set sb = oTransientBRep.CreateIntersectionWithPlane(oCompDef.SurfaceBodies.Item(1), pl)
    Dim w As Wire
    Dim e As Edge
    For Each w In sb.Wires
        For Each e In w.Edges
            Dim ce As CurveEvaluator
            Set ce = e.Geometry.Evaluator
            Dim min As Double
            Dim max As Double
            ce.GetParamExtents min, max
            Dim vc As Long
            Dim coords() As Double
            ce.GetStrokes min, max, 0.01, vc, coords ' <- boom !
' e.Evaluator.GetStrokes min, max, 0.01, vc, coords ' OK Next e Next w End Sub
Use it on a cylinder part.
Maxence DELANNOY
Manager
http://wiip.fr
Message 7 of 10
adam.nagy
Autodesk Support
Autodesk Support
Hi Maxence,
I installed SP1 which was painful - maybe something is wrong with my VM - and got stuck in the end so I had to restart.
Still, it says that it has SP1 installed and I cannot reproduce the issue. Now I'm not sure if my install is missing something that is needed for the behaviour to appear. :-s
Can you reproduce it with ANY cylindrical part? What happens if you migrate the part to Inventor 2016 SP1 - i.e. save it in that version?
Cheers,
Adam Nagy
Message 8 of 10
adam.nagy
Autodesk Support
Autodesk Support
I could reproduce it after all I just had the sketch in another plane, not XY. I thought you meant to say that it was a 2016 SP1 issue, but I found the same in Inventor 2015 as well.
Have logged it in our system: #126239
Any issue with the workaround you found of using "e.Evaluator.GetStrokes min, max, 0.01, vc, coords" instead?
Adam Nagy
Message 9 of 10
FRFR1426
e.Evaluator.GetStrokes works, no problem so far. But for me it crashes also when the sketch is on the XY plane (see IPT attached).
Maxence DELANNOY
Manager
http://wiip.fr
Message 10 of 10
adam.nagy
Autodesk Support
Autodesk Support
Sorry, I did not put it clearly.
What I mean to say was "I could reproduce it after all I just originally had the sketch in another plane, not XY - and that's why I could not reproduce the issue. Once the sketch was on the XY plane I could reproduce the behaviour." 🙂
Adam Nagy
