Couple questions regarding to Addin
Message 1 of 10
I just played a bit with some sample AddIns in SDK and feel more
comfortable to create one now. Just couple questions hope someone here can
help me
1) How to set the form on top, same level with IV, when you run an addin.
I tried ScanDrawingViews add in and each time I click on IV window, it's on
top of the ScanDrawingViews window
2) I still have trouble to get the icons shown in the panel tool bar
Thx, Chris
IV11 Pro. sp1 (uninstall)
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 84.26
SpacePilot V 1.1.2
Replies (9)
Message 2 of 10
This might help.
http://www.devx.com/vb2themax/Tip/19200
Message 3 of 10
Rene-J
Hi Chris
call your form
1) Formname.Show vbModal
2) You have maybe all ready load your icon.
check in the tools-customize-commands -addin
the icon will only be load the first time.
Your run the Addin.
Regards
René J
Message 4 of 10
Thanks, Peter. I don't want "always ontop all windows" - but ontop of IV
window only
Chris
wrote in message news:5269382@discussion.autodesk.com...
This might help.
Message 5 of 10
And another question:
VB6 only allows you to open one project at a time. what's the trick to copy
and paste code between projects
Thx, Chris
"Chris (IV11 Pro. SP1 (uninstall)" wrote in message
news:5269345@discussion.autodesk.com...
help me
Thx, Chris
Window XP Pro sp2
SpacePilot V 1.1.2
Message 6 of 10
Two sessions of VB6 ....
Message 7 of 10
Try this:
Add the following to a module in your add-in:
Public Const GWL_HWNDPARENT = (-8)
Public Declare Function SetWindowLong Lib "user32" Alias
"SetWindowLongA" _
(ByVal hwnd As Long, ByVal nIndex As Long, ByVal wNewLong As Long)
As Long
Add the following variable declaration as a form level variable in your
form:
'form level variable declaration
Private originalParenthWnd As Long
Add the following to the form_Load event for your form:
'set form to always be on top of Inventor window, but minmize along
with Inventor
'note that ivApp is a reference to the Inventor.Application object
(must be assigned prior to calling this function)
originalParenthWnd = SetWindowLong(Me.hwnd, GWL_HWNDPARENT,
ivApp.MainFrameHWND)
Add the following to the form_Unload event for your form:
'restore the original parent window before unloading
Call SetWindowLong(Me.hwnd, GWL_HWNDPARENT, originalParenthWnd)
Neil
news:5269384@discussion.autodesk.com...
window only
Chris
This might help.
Message 8 of 10
I got this error mesg at the line (see the att.) : Me.hwnd
Thx, Chris
"Neil Munro" wrote in message
news:5269451@discussion.autodesk.com...
Try this:
"SetWindowLongA" _
As Long
form:
with Inventor
Neil
window only
Chris
This might help.
Message 9 of 10
The attached code has some word wrap issues. The attached text file has the
correct formatting.
Neil
news:5272563@discussion.autodesk.com...
Message 10 of 10
Thanks, Neil. I finally had a chane to try it and it works nicely
Chris
news:5272769@discussion.autodesk.com...
correct formatting.
Neil
