Add a button
Add a button
Message 1 of 29
Add a button
Hi all,
I used ScanDrawingViews addin as a template and add a extra button. The
program works fine, howver, the second button called oButtonDefPart is not
shown up in IV. Anyone please see the code
Thx, Chris
Implements ApplicationAddInServer
Private WithEvents oButtonDefScanDrawingViews As ButtonDefinition
Private WithEvents oButtonDefPart As ButtonDefinition '
Private oInventorApp As Inventor.Application
Private Sub ApplicationAddInServer_Activate(ByVal AddInSiteObject As
Inventor.ApplicationAddInSite, ByVal FirstTime As Boolean)
' Save a reference to the Application object.
Set oInventorApp = AddInSiteObject.Application
'create the button to create the text graphics
Set oButtonDefScanDrawingViews =
oInventorApp.CommandManager.ControlDefinitions.AddButtonDefinition("ScanDrawingViews",
_
"ScanDrawingViewsCmdIntName",
kQueryOnlyCmdType, "{0E2365C9-C7A2-4304-9B1C-29285781218A}", _
"Scan Drawing Views", "Scan Drawing
Views")
Set oButtonDefPart =
oInventorApp.CommandManager.ControlDefinitions.AddButtonDefinition("Part",
"Generate a Part", kQueryOnlyCmdType, _
"{0E2365C9-C7A2-4304-9B1C-29285781218A}", "Part",
"Generate a part")
'enable the button
oButtonDefScanDrawingViews.Enabled = True
oButtonDefPart.Enabled = True
'if AddIn is called first time, create toolbar and add button to toolbar
If FirstTime = True Then
'create a new toolbar
Dim oCommandBar As CommandBar
Set oCommandBar =
oInventorApp.UserInterfaceManager.CommandBars.Add("ScanDrawingViews",
"ScanDrawingViewsToolbarIntName", , _
"{0E2365C9-C7A2-4304-9B1C-29285781218A}")
'add the button to the toolbar
oCommandBar.Controls.AddButton oButtonDefScanDrawingViews
oCommandBar.Controls.AddButton oButtonDefPart
'make the toolbar visible
oCommandBar.Visible = True
End Sub
IV11 Pro. sp1 (uninstall)
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 84.26
SpacePilot V 1.1.2
Replies (28)
Message 2 of 29
Never mind, Everyone. Nothing wrong with the code.
I opened control panel - add/remove program to remove the the old addin.
Made .dll again and run IV then I saw 2 buttons in the command bar
My question is: Every time making a modification to the code, do I have to
1) Go to Control Panel and remove the old addin
2) Uninstall the .exe file ( I used Inventor Addin Scrip builder from Mr.
Bliss)
3) Remake the .dll
4) Run the Scrip builder again
5) Lauch IV to see to the code working not not ????
Thx, Chris
"Chris (IV11 Pro. SP1 (uninstall)" wrote in message
news:5269010@discussion.autodesk.com...
Hi all,
Thx, Chris
_
Views")
"Generate a part")
'enable the button
Set oCommandBar =
End Sub
Window XP Pro sp2
SpacePilot V 1.1.2
Message 3 of 29
Sounds like you MIGHT have your VB6? project set to generate
a new UUID everytime it's compiled. I believe the correct option
for this is from the Project Properties dialog, Component tab,
Version Compatibility, make sure it's set to "Project Compatibility",
then be sure to specify your output dll file in the file box immediately
below the 3 option buttons.
Chris wrote:
Message 4 of 29
Yes, I have VB6 and the setup is exactly as what you describe
Seems like I have to go thru steps each time I modify the code
Chris
"Bob S." wrote in message
news:5269118@discussion.autodesk.com...
Chris wrote:
Message 5 of 29
I have been just editing the code, compile it and save over the old dll. My edits seem to be there..
Wayne
Message 6 of 29
Are you running the .reg file after recompiling? I know I have
to do that, but that is all.
My steps:
Before compiling, exit Inventor.
Compile
Run .reg file
Run Inventor
Bob
Chris wrote:
Message 7 of 29
I have been just:
Compile
Run Inventor
Is this wrong?
Message 8 of 29
It is for me!
I need the following
Exit IV
Compile
Run reg file
Restart IV
Message 9 of 29
I use scrip builder from Mr. Bliss and skip runing reg file
just
Exit IV
make .dll.
Run scrip builder
restart IV
wrote in message news:5269295@discussion.autodesk.com...
It is for me!
Exit IV
Compile
Run reg file
Restart IV
Message 10 of 29
What happened to:
Bliss)
3) Remake the .dll
Thx, Chris
? If you are having to uninstall before using the script builder,
just try running the .reg file next time.
Bob S.
> just
> Exit IV
> make .dll.
> Run scrip builder
> restart IV
Message 11 of 29
I think the problem may be that your user-interface has already been created
so the FirstTime argument being passed into your add-in in the Activate
method is False. If your code is correct it should be checking this
argument and only creating your user-interface when this is True.
The idea is that the first time your add-in is loaded for a particular user,
your add-in creates its user-interface the way it wants. Inventor remembers
what has been created and restores it automatically for the next session.
This is done so that any edits to the user-interface that the end-user does
will be maintained. For example, let's say your add-in creates a new
toolbar with three buttons. The end-user might decide he doesn't want
another toolbar and decides to move those three buttons to the part panel
bar and delete your toolbar. That's ok because Inventor remembers these
changes and hooks up your ButtonDefinition objects to these button controls.
The problem with the approach we've decided to take is that it's a bit of a
pain for the developer when you're developing the user-interface portion of
your program. You're probably making changes frequently to the
user-interface and want that code to be executed each time. What I do is
just delete the portion of the registry where Inventor remembers which
add-ins have been loaded and what changes have been made to the
user-interface. By deleting this the next time you run Inventor it will
reset the user-interface to the default state and call all add-in's as if
its the first time they've been loaded.
The registry key is:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion11.0\UI
Customization V4
As always, be careful when deleting anything from the registry. When you
delete it make sure Inventor is not running.
Brian Ekins
Autodesk Inventor API
Message 12 of 29
Brian,
I am creating my very first addin. I did not try to move the icon around to
another IV toolbar or delete the new toolbar
I used scrip builder from Mr. Bliss to add and remove register file each
time I compile the .dll - it works great so far.
I still have trouble to load the .ico file and show it in IV
I tried SampleAddin (included with IV) many times and never got the 2 icons
shown up.
I replaced this line
Set oButtonDefPrimary =
oInventorApp.CommandManager.ControlDefinitions.AddButtonDefinition("Primary",
"Primary2", _
kQueryOnlyCmdType,
"{0E2365C9-C7A2-4304-9B1C-29285781218A}", "Primary", "Primary2")
With
Dim oPriIcon As IPictureDisp
Set oPriIcon = LoadPicture(App.Path & "\Primary.ico")
"Primary2", _
kShapeEditCmdType,
"{DB59D9A7-EE4C-434A-BB5A-F93E8866E872}", "Primary", "Primary2", oPriIcon,
oPriIcon)
The first line works but the second one with Primary.ico doesn't
Thx, chris
"Brian Ekins (Autodesk)" wrote in message
news:5270971@discussion.autodesk.com...
Customization V4
Brian Ekins
Message 13 of 29
Chris,
You should look into compiling the icon file into your addin by
putting it in a resource file (.res), then use LoadResPicture
instead of LoadPicture. Also make sure the icons are the right
size and format (256 color).
Bob
Chris wrote:
Message 14 of 29
Bob,
How you create a icon file? I've been using IconArt to create all my icons
and it works fine for all my VBA codes
Now I'm trying it in AddIn and it seems to have trouble
Chris
news:5271705@discussion.autodesk.com...
Chris,
Bob
Chris wrote:
Message 15 of 29
Chris,
In VB6, pick the Project Menu->Add New Resource File
to create an empty resource file, then from the Tools
menu you can access the Resource Editor. Or you can
create the resource file right from the Resource Editor.
From there you should be able to figure out how to add
the icons into the resource file, and the help for
LoadResPicture().
Bob
Chris wrote:
> Bob,
> Chris
> Chris,
> Bob
> Chris wrote:
Message 16 of 29
The point I was trying to make is that it's likely that your code to create
the button is never being called because the FirstTime argument of the
Active method is False. If you've run your Add-In before then the FirstTime
will be False. Editing the user-interface has nothing to do with this,
except this is done so that editing of the user-interface behaves correctly.
Deleting the registry key will reset this so that FirstTime will return True
the next time your Add-In is loaded.
Brian Ekins
Message 17 of 29
Brian,
I wasn't trying to take away from your registry tip, but just wanted to
add that I think storing the icons in a resource file that gets compiled
into the addin usually works better than trying to access one from disk.
Bob
Message 18 of 29
I think I've done something very funny here. As a result, my help files are
disappeared.
Do you have any idea how to get it back
Thx, Chris
news:5271824@discussion.autodesk.com...
Chris,
LoadResPicture().
Bob
Chris wrote:
> Bob,
> Chris
> Chris,
> Bob
> Chris wrote:
Message 19 of 29
You can probably access online help files at
http://msdn.microsoft.com or there are several good information
sites on the internet. Simply try a search on LoadResPicture
or VB6 Resource Files. For instance, my first item in Google
search was:
http://msdn.microsoft.com/library/en-us/vb98/html/vbmthLoadResPicture.asp?frame=true
Start there.
Bob
> disappeared.
> Thx, Chris
> Chris,
Message 20 of 29
I understand Bob and I appreciate you taking time to provide help in this
newsgroup. It just seemed that Chris missed the point of that post and I
just wanted to clarify.
Brian Ekins
news:5271909@discussion.autodesk.com...
Brian,
Bob
> create
> FirstTime
> correctly.
> True
