Count up and down parameter value with slider bar
Does anybody know how to count up or down the value of a parameter with a slider bar.
For example I want to change the parameter "Distance" between the value of 0 and 7000 mm with steps of 1 mm , with the help of using a sliderbar  (up - down)
When changing the sliderbar the assembly should update immediatly
Is this possible with iLogic or do i need VBA
MjDeck
In Inventor 2012, you can do it with an iLogic Form.  In Inventor 2011 or before you would have to use VBA or VB.NET.
Mike Deck
Software Developer
Autodesk, Inc.
Hi Mike, Thanks,
I'm searching to find the sliderbar that i can attach to the parameter in iLogic but i can't find it.
I'm using Inventor 2012
Thank if you can help me.
MjDeck
The Add Form command is hidden in the drop down under the iLogic panel on the Manage tab:
That command will put you in the Form Editor.  Dragging a parameter from the left to the right will add it to the form.  To attach a slider to it, click o nthe parameter on the right and look at the Properties.  Change the property named Edit Control Type.
Mike Deck
Software Developer
Autodesk, Inc.
