Copying without effecting the original assembly
I have made a wood panel with capabilities to be made adaptive but when i place it into a drawing using the place command i cannot seem to copy it any of the different ways without it being attached and/or effecting the original. I would like to refrain from designing a second because there are many panels in each room and it would take a long time. I'm sure I'm just forgetting something simple and it's causing this to occur.
Please help me if someone can...
Thank you in advanced
matt_jlt
You seem to have only uploaded the assembly file, you need to upload all of the parts as well.
it might be easier to put your files in a .zip file and upload it.
Also, from what i understand your question might be better asked in the Inventor Forum not the Customization Forum. You will probably get a faster response in the correct one.
Regards, Matt.
thank you and moved to proper location with a zipped file
