Copy Surface to right position in other part
rikard.nilsson
rikard.nilsson
I really can't understand this with Matrix.
In the attached zip you can find a very simple assembly with 3 parts..
But I can't have my copied surfaces to be placed in the right position in my CopyToOcc..
If my CopyToOcc has the same directions as top-assy then it works but not if I turn it..
Is there someone who can tell me how to code this so the surfaces will be placed in the same position and rotations as my occurrences that I copy from.
Regards
Rikard
SyntaxEditor Code Snippet
    Dim oAssemblyDef As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
    Dim CopyToOcc As ComponentOccurrence = Component.InventorComponent("CopyToOcc")
    Dim CopyToOccDef As PartComponentDefinition = CopyToOcc.Definition
    Dim CopyFromOcc1 As ComponentOccurrence = Component.InventorComponent("CopyFromOcc1")
    Dim CopyFromOcc1Def As PartComponentDefinition = CopyFromOcc1.Definition
    Dim CopyFromOcc2 As ComponentOccurrence = Component.InventorComponent("CopyFromOcc2")
    Dim CopyFromOcc2Def As PartComponentDefinition = CopyFromOcc2.Definition
    Dim oSourceBody As SurfaceBody = CopyFromOcc1Def.Worksurfaces.Item(1).Surfacebodies(1)
    Dim oSourceBody1 As SurfaceBody = CopyFromOcc2Def.Worksurfaces.Item(1).Surfacebodies(1)
    Dim CopyFromOcc1Matrix As Matrix
    CopyFromOcc1Matrix = CopyFromOcc1.Transformation
    Dim CopyFromOcc2Matrix As Matrix
    CopyFromOcc2Matrix = CopyFromOcc2.Transformation
    Dim CopyToOccMatrix As Matrix
    CopyToOccMatrix = CopyToOcc.Transformation
    CopyToOccMatrix.PreMultiplyBy(CopyFromOcc1Matrix)
    Dim nonprmFea As NonParametricBaseFeature = CopyToOccDef.Features.NonParametricBaseFeatures.Add(oSourceBody, CopyToOccMatrix)
    CopyToOccMatrix = Nothing
    CopyToOccMatrix.PreMultiplyBy(CopyFromOcc2Matrix)
    Dim nonprmFea1 As NonParametricBaseFeature =  CopyToOccDef.Features.NonParametricBaseFeatures.Add(oSourceBody1, CopyToOccMatrix)
   oAssemblyDoc.Update
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Rikard,
Please find the sample code to create surface at same position and rotations.
Sub Main()
    Dim oAssemblyDoc As AssemblyDocument = ThisApplication.ActiveDocument
    Dim oSurfaceproxy As SurfaceBodyProxy
    CopyFromOcc1.CreateGeometryProxy(oSourceBody, oSurfaceproxy)
    Dim oSurfaceproxy1 As SurfaceBodyProxy
    CopyFromOcc2.CreateGeometryProxy(oSourceBody1, oSurfaceproxy1)
    Dim oBody1 As SurfaceBody
    oBody1 = ThisApplication.TransientBRep.Copy(oSourceBody)
    ThisApplication.TransientBRep.Transform(oBody1, oSurfaceproxy.ContainingOccurrence.Transformation)
    Dim trans1 As Matrix
    trans1 = CopyToOcc.Transformation
    trans1.Invert()
    ThisApplication.TransientBRep.Transform(oBody1, trans1)
    Dim oBody2 As SurfaceBody
    oBody2 = ThisApplication.TransientBRep.Copy(oSourceBody1)
    ThisApplication.TransientBRep.Transform(oBody2, oSurfaceproxy1.ContainingOccurrence.Transformation)
    Dim trans2 As Matrix
    trans2 = CopyToOcc.Transformation
    trans2.Invert()
    ThisApplication.TransientBRep.Transform(oBody2, trans2)
    CreateBaseFeature(CopyToOccDef, CopyToOcc, oBody1)
    CreateBaseFeature(CopyToOccDef, CopyToOcc, oBody2)
    oAssemblyDoc.Update
End Sub
Sub CreateBaseFeature(ByVal targetDef As PartComponentDefinition, ByVal targetOcc As ComponentOccurrence, ByVal body As SurfaceBody)
        Dim nonPrmFeatures As NonParametricBaseFeatures
        nonPrmFeatures = targetDef.Features.NonParametricBaseFeatures
        Dim featureDef As NonParametricBaseFeatureDefinition
        featureDef = nonPrmFeatures.CreateDefinition
        Dim transObjs As TransientObjects
        transObjs = ThisApplication.TransientObjects
        Dim col As ObjectCollection
        col = transObjs.CreateObjectCollection
        col.Add(body)
        featureDef.BRepEntities = col
        featureDef.OutputType = BaseFeatureOutputTypeEnum.kSurfaceOutputType
        featureDef.TargetOccurrence = targetOcc
        featureDef.IsAssociative = False
        Dim baseFeature As NonParametricBaseFeature
        baseFeature = nonPrmFeatures.AddByDefinition(featureDef)
End Sub
Please feel free to contact if there is any doubt.
If solves your problem, Click on "Accept as Solution" / Give a kudo.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
