Copy part of "part name" to "description" iProperties with vba
jorgen_dahlstrom
Message 1 of 25
jorgen_dahlstrom
Hi
Wondering if someone could help me with this:
I want to copy just a part of a part name to description field in iProperties.
ex. I save a part with name: 123A001 Motor Assy for example
After save the part number will be "123A001 Motor Assy" in iProperties
I want to cut "Motor Assy" and paste it to description field as following:
Part Number: 123A001
Description: Motor Assy
I manage to copy the whole part name to Description field with following code:
Sub Main()
    ' Get the active document.
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the PropertySets object.
    Dim oPropSets As PropertySets
    Set oPropSets = oDoc.PropertySets
    ' Get the design tracking property set.
    Dim oPropSet As PropertySet
    Set oPropSet = oPropSets.Item("Design Tracking Properties")
    ' Get the part number iProperty.
    Dim oPartNum_iProp As Property
    Set oPartNum_iProp = oPropSet.Item("Part Number")
    ' Get the description iProperty.
    Dim oDesc_iProp As Property
    Set oDesc_iProp = oPropSet.Item("Description")
    ' Copy part number to description
    oDesc_iProp.Value = oPartNum_iProp.Value
End Sub
...but I can't figure out how to cut the describing text.
FYI there is always space between the partnumber and describing text so maybe that can be used as a separator, however it can also be space in the describing text...
Any one?
/ Jorgen
Replies (24)
Message 21 of 25
ThatWorksForMe
Use iLogic
- create a new rule with the following content:
Sub Main()
	InventorVb.RunMacro("1", "2", "3")
End Sub
   1, 2 and 3 are mentioned in the screenshot
   in this example the code would be:
InventorVb.RunMacro("Anwendungsprojekt", "Drucken", "TEST123")
- add a new rule to the action "before save document"
- run the rule
PDM/CAD Administrator
Using Inventor/Vault 2024.3
Message 22 of 25
jorgen_dahlstrom
I suck at this!
I got error on "No VBA project named "1" was found"...
I belive that 1 should stand for something also 2 & 3
like project name, module name macro name but when I trying to put in the project name I got errors
Message 23 of 25
ThatWorksForMe
Take a look on the attached file.
Message 24 of 25
jorgen_dahlstrom
Now it works..
/ Jorgen
Message 25 of 25
ThatWorksForMe
Perfect
