Copy part of "part name" to "description" iProperties with vba
jorgen_dahlstrom
Message 1 of 25
jorgen_dahlstrom
Hi
Wondering if someone could help me with this:
I want to copy just a part of a part name to description field in iProperties.
ex. I save a part with name: 123A001 Motor Assy for example
After save the part number will be "123A001 Motor Assy" in iProperties
I want to cut "Motor Assy" and paste it to description field as following:
Part Number: 123A001
Description: Motor Assy
I manage to copy the whole part name to Description field with following code:
Sub Main()
    ' Get the active document.
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the PropertySets object.
    Dim oPropSets As PropertySets
    Set oPropSets = oDoc.PropertySets
    ' Get the design tracking property set.
    Dim oPropSet As PropertySet
    Set oPropSet = oPropSets.Item("Design Tracking Properties")
    ' Get the part number iProperty.
    Dim oPartNum_iProp As Property
    Set oPartNum_iProp = oPropSet.Item("Part Number")
    ' Get the description iProperty.
    Dim oDesc_iProp As Property
    Set oDesc_iProp = oPropSet.Item("Description")
    ' Copy part number to description
    oDesc_iProp.Value = oPartNum_iProp.Value
End Sub
...but I can't figure out how to cut the describing text.
FYI there is always space between the partnumber and describing text so maybe that can be used as a separator, however it can also be space in the describing text...
Any one?
/ Jorgen
Replies (24)
Message 2 of 25
ThatWorksForMe
Sub Main()
    oDesc_iProp.Value = Replace(oPartNum_iProp.Value, Left(oPartNum_iProp.Value,8), "")
oPartNum_iProp.Value = Left(oPartNum_iProp.Value,7)
End Sub
This will work when the number is always 7 signs long. Its not tested. Try it.
PDM/CAD Administrator
Using Inventor/Vault 2024.3
Message 3 of 25
dgreatice
Try This,
Public Sub Main()
SavedString = Split(oPartNum_iProp.Value, " ")
oPartNum_iProp.Value = SavedString(0)
'Because you use space delimiter , it become " ".
oDesc_iProp.Value = SavedString(1) & " " & SavedString(2)
End Sub
try to save that file 1234_Motor Assy
SavedString = Split(oPartNum_iProp.Value, "_")
SavedString(0) = 1234
SavedString(1) = Motor Assy
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 25
jorgen_dahlstrom
Thanks, but now I copied the part number to Description field, it should be the otherway around, the descriptions text should be cut and copied to the description field...
But thanks anyway
/Jorgen
Message 5 of 25
dgreatice
did you try my code?
with "SPLIT" Command
Message 6 of 25
jorgen_dahlstrom
Super that worked!!
Thanks alot!
/ Jorgen
Message 7 of 25
dgreatice
Beware
If you save tht file with 1234 motor
It will error, because string(2) is nothing
If you save with 1234 nord motor assy
The result of description only "nord motor"
Message 8 of 25
jorgen_dahlstrom
Yes I saw that
But couldn't I use "if, else, end if" here to define which string contains information and only write out the ones that have information?
I must say that I am not so familiar in vba so you have to excuse me..
/ Jorgen
Message 9 of 25
ThatWorksForMe
The code from dgeatice does the same as my code does but cuts the name if more than 2 spaces are in the name.
I have tested my code and it does what you have described.
Message 10 of 25
jorgen_dahlstrom
Well, your code copies the part number to description.
But the question was how do I keep the part numer in the "part number" field, cut away the description text "Motor Assy" and paste that text into the description field.
And also if there are mor than one space in the text
I must say I am impressed by how quick you responce here..very nice!
/ Jorgen
Message 11 of 25
jorgen_dahlstrom
Hey, I was a little to fast here, yes your code works..
But if the partnumber only contains 6 letters/digits and a description name can you solve that too?
Message 12 of 25
ThatWorksForMe
Ok, maybe there is an other problem. I dont know.
However, You have a solution that works for you. That's what the community is for. 😉
 *EDIT*
One moment.
Message 13 of 25
ThatWorksForMe
 Sub Main()
oDesc_iProp.Value = Trim(Replace(oPartNum_iProp.Value, SavedString(0), ""))
End Sub
Try this
Message 14 of 25
jorgen_dahlstrom
Well, it works when it is 7 letters, but with 6 letters it removes the first letter after the first space
If you understand what I mean.
ex. Part Name: 123456 Test 1 test 2 test 3
Result:
Part Name: 123456
Derscription: est 1 test 2 test 3
/ Jorgen
Message 15 of 25
ThatWorksForMe
Yes I found the mistake and made the code above right. Just test it again.
Message 16 of 25
dgreatice
I'm propose to use special delimiter
in you example, you use space delimiter.
1234 motor assy.
example if you use "_":
1234_motor assy
part number =1234
description =motor assy
another case:
1234_motor assy_nord
part number :1234
description = motor assy
vendor = nord
It will be easy to extract.
but if still using space delimiter,
first text (SavedText(0)) used for Part Number
and another will be Description.
so we must count first
actually code update like :
Public Sub Main()
i = 0
For Each Item In SavedString
i = i + 1
Next
If i > 1 Then
For x = 2 To i
CombineString = CombineString & " " & SavedString(x - 1)
Next
CombineString = Trim(CombineString)
oDesc_iProp.Value = CombineString
Else
'Do nothing
End Sub
Message 17 of 25
jorgen_dahlstrom
Awsome man..it works!
Thanks alot!
/ Jorgen
Message 18 of 25
ThatWorksForMe
No problem. 😉
Message 19 of 25
dgreatice
Great,
I'm forgot it can be use Replace
Message 20 of 25
jorgen_dahlstrom
Haha..next problem..
How do I run the macro when I save my file?
Can I use iLogic and the event trigger or should I do something else?
/ Jorgen
