- Mute
- Permalink
- Report
i'm using iLogic to create some layers by copying an existing one. The layer copies but is not put in the 'Active Standard'. This means when I select the layer drop down list I do not see the layer unless i scroll to the bottom:
Is there a way to add the new layer to the Active Standard so that the layer appears in list correctly? (this is what happens when I manually copy a layer through the styes editor.
thanks,
John
