Copy iProperty based on File Name
donaldleigh
donaldleigh
Hi all
Can I ask for a little help on this please. I can't work this out. taken me 2 days so far. Not even sure if it can be done.
I have been using the below code for a while now and it works perfect. (Thanks to MechMachineManI would now like to change it a little.
From my Top Level assembly I would like to send either the iProperty "Qty Required A" or "Qty Required B" to each sub assembly and part based on their file name.
If the file name of a Sub assembly or part is say "Board Assembly" or "Board Weldment" then all sub assemblies and parts of "Board Assembly" or "Board Weldment" are to read "Qty Required B". This assembly or part could be 2 or 3 deep in the top level assembly.
Anything else and it reads "Qty Required A"
Please let me know if I have not explained it well.
SyntaxEditor Code Snippet
Dim openDoc As Document
openDoc = ThisDoc.Document
If openDoc.DocumentType <> 12291 Then
    MsgBox("You must have a document open to run this rule!")
    Exit Sub
End If
Dim BatchQty As Double
Try
    BatchQty = iProperties.Value("Custom", "Qty Required")
Catch
    MsgBox("No 'Qty Required' iProp found in this doc" & vbLf & vbLf & "Aborting rule!")
    Exit Sub
End Try
 Dim docFile As Document
 For Each docFile In openDoc.AllReferencedDocuments
        Dim docFName As String
        docFName = System.IO.Path.GetFileName(docFile.FullFileName)
        If docFile.IsModifiable = True Then
            Dim assemblyDef As AssemblyComponentDefinition
            assemblyDef = openDoc.ComponentDefinition
            Dim partQty As Double
            partQty = assemblyDef.Occurrences.AllReferencedOccurrences(docFile).Count
            Try
                oCheck = iProperties.Value(docFName, "Custom", "Qty Required")
            Catch
                iProperties.Value(docFName, "Custom", "Qty Required") = 0
            End Try
            If partQty <> CDbl(iProperties.Value(docFName, "Custom", "Qty Required")) Then
                iProperties.Value(docFName, "Custom", "Qty Required") = partQty*BatchQty
                'MessageBox.Show(docFName, "Title")
            End If
        End If
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @donaldleigh,
Try below iLogic code.
Sub Main()
    Dim oDoc = ThisDoc.Document
    Dim oDef As AssemblyComponentDefinition
    oDef = oDoc.ComponentDefinition
    Dim BatchQty_A As Double
    Dim BatchQty_B As Double
    Try
        BatchQty_A = iProperties.Value("Custom", "Qty Required A")
    Catch
        MsgBox ("No 'Qty Required A' iProp found in this doc" & vbLf & vbLf & "Aborting rule!")
        Exit Sub
    End Try
    Try
        BatchQty_B = iProperties.Value("Custom", "Qty Required B")
    Catch
        Exit Sub
    End Try
    Dim PartQty As Double
    Dim occ As ComponentOccurrence
    For Each occ In oDef.Occurrences
        If occ.Name Like "Board Assembly*" Or occ.Name Like "Board Weldment*" Then
            If occ.DefinitionDocumentType = kAssemblyDocumentObject Then
                PartQty = oDef.Occurrences.AllReferencedOccurrences(occ.Definition.Document).Count
                Call UpdateBatchQty(occ.Name, PartQty, BatchQty_A)
                Call GetSubOccurrences(occ.SubOccurrences, oDef, BatchQty_A)
            Else
            End If
        Else
            Call UpdateBatchQty(occ.Name, PartQty, BatchQty_B)
        End If
    Next
End Sub
Private Sub GetSubOccurrences(Occurrences As ComponentOccurrences, oDef As AssemblyComponentDefinition, BatchQty_A As Double)
    ' Iterate through each of the occurrences in the collection provided.
    For Each occ In Occurrences
        End If
    Next
End Sub
Sub UpdateBatchQty(occName As String, PartQty As Double, BatchQty As Double)
    Try
        oCheck = iProperties.Value(occName, "Custom", "Qty Required")
    Catch
        iProperties.Value(occName, "Custom", "Qty Required") = 0
    End Try
    If PartQty <> CDbl(iProperties.Value(occName, "Custom", "Qty Required")) Then
        iProperties.Value(occName, "Custom", "Qty Required") = PartQty * BatchQty
    End If
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
donaldleigh
Hi Chandra
I have been busy this week with other project and will check this out soon I hope
Donald
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Check the same and let me know if there is any assistance needed.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
donaldleigh
Hi Chandra
Thanks for the updated code
It works only if the "Board Assembly" or "Board Weldment" are sub assemblies in the assembly where the rule is run
Problem is that these are normally 2 deep. See attached.
If I run your new code in the Assembly "General Assembly" it all works great but not when run in the top level "General Arrangement" . The code will only be run in the very Top level "General Arrangement".
Cheers
Donald
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Hoping that below iLogic would help now.
Sub Main()
    Try
    Catch
        Exit Sub
    End Try
    Try
    Catch
        Exit Sub
    End Try
		If occ.SubOccurrences.count = 0 Then
			Else
			End If
		Else
			TraverseSubOccurrences(occ.SubOccurrences,oDef, BatchQty_A,BatchQty_B)
		End If
    Next
End Sub
Private Sub TraverseSubOccurrences(Occurrences As ComponentOccurrences, oDef As AssemblyComponentDefinition, _
BatchQty_A As Double, BatchQty_B As Double)
	Dim occ As Inventor.ComponentOccurrence
			Else
			End If
		Else
			Else
			End If
		End If
	Next
End Sub
        End If
    Next
End Sub
    Try
    Catch
    End Try
    End If
End Sub
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution' / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
