Copy idws of main assembly and all regarding subassemblies to one folder
damjan_baraga
damjan_baraga
I want to copy idws of main assembly and all regarding subassemblies into one folder. Idw for assembly  are saved in extra folder, which is in project folder. I made rule which copy only file only from Library.
Sub Main()
    ' Define the target folder where all .idw files will be copied
    Dim targetFolder As String = "C:\Users\damjan\Desktop\Nova mapa"
    ' Ensure the target folder exists
    If Not System.IO.Directory.Exists(targetFolder) Then
        System.IO.Directory.CreateDirectory(targetFolder)
    End If
    ' Start the process with the current assembly
    CopyIDWFiles(ThisDoc.Document, targetFolder)
    MsgBox("All .idw files have been copied to: " & vbLf & targetFolder)
End Sub
' Function to recursively find and copy .idw files
Sub CopyIDWFiles(document As Document, targetFolder As String)
    ' Check if the document has an associated drawing file
    Dim drawingPath As String = System.IO.Path.ChangeExtension(document.FullFileName, ".idw")
    If System.IO.File.Exists(drawingPath) Then
        ' Copy the .idw file to the target folder
        Dim fileName As String = System.IO.Path.GetFileName(drawingPath)
        Dim destinationPath As String = System.IO.Path.Combine(targetFolder, fileName)
        If Not System.IO.File.Exists(destinationPath) Then
            System.IO.File.Copy(drawingPath, destinationPath)
            MsgBox("Copied: " & vbLf & fileName)
        Else
            MsgBox("Skipped (already exists): " & vbLf & fileName)
        End If
    End If
    ' If the document is an assembly, process its subcomponents
    If document.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim assemblyDoc As AssemblyDocument = document
        Dim occurrences As ComponentOccurrences = assemblyDoc.ComponentDefinition.Occurrences
        For Each occurrence As ComponentOccurrence In occurrences
            If occurrence.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Or occurrence.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
                ' Recursively process subassemblies and parts
                CopyIDWFiles(occurrence.Definition.Document, targetFolder)
            End If
        Next
    End If
End Sub
damjan_baraga
Recantly, I find out that the idw must be in same folder as assembley or subassembley. Soo, i need code to get those idw, what ever they are for ex. like inventor find IDW  from Assembley.
