Copy hole settings
Copy hole settings
GeorgK
Advisor Advisor
Message 1 of 25
Copy hole settings
GeorgK
Hello together,
I am searching for a possibility to copy the hole dimensions and open the dialogbox with those settings or to copy the settings and paste it on an existing hole.
http://forums.autodesk.com/t5/inventor-ideas/copy-hole-properties/idi-p/5655082
Georg
Replies (24)
Message 21 of 25
wayne.brill
Hi Georg,
Here is an update to the code that resolves the problem when copying hole 13 when the target hole has threads. (hole 40)
It also now uses the TargetHole.Extent.Direction instead of the SourceHole.Extent.Direction. Seems to get the correct results.
Public Sub Modify_Holes_2()
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    Dim SourceHole As Object
    Dim TargetHole As HoleFeature
    Dim oHoles As HoleFeatures
    Set oHoles = invDoc.ComponentDefinition.Features.HoleFeatures
   '  Set SourceHole = oHoles("Hole11")
    Set SourceHole = oHoles("Hole13")
   ' Set SourceHole = oHoles("Hole40")
   For Each TargetHole In oHoles
      ' Debug.Print SourceHole.name
       Debug.Print TargetHole.name
        If SourceHole.Tapped = False And TargetHole.Tapped = True Then
             TargetHole.Tapped = False
             TargetHole.HoleDiameter.value = SourceHole.HoleDiameter.value
        If SourceHole.HoleType = kCounterBoreHole Then Call TargetHole.SetCBore(SourceHole.CBoreDiameter.value, SourceHole.CBoreDepth.value)
        If SourceHole.HoleType = kCounterSinkHole Then Call TargetHole.SetCSink(SourceHole.CSinkDiameter.value, SourceHole.CSinkAngle.value)
        If SourceHole.HoleType = kSpotFaceHole Then Call TargetHole.SetSpotFace(SourceHole.SpotFaceDiameter.value, SourceHole.SpotFaceDepth.value)
        If SourceHole.HoleType = kDrilledHole Then Call TargetHole.SetDrilled
        'If SourceHole.ExtentType = kThroughAllExtent Then Call TargetHole.SetThroughAllExtent(SourceHole.Extent.Direction)
        If SourceHole.ExtentType = kThroughAllExtent Then Call TargetHole.SetThroughAllExtent(TargetHole.Extent.Direction)
        If SourceHole.ExtentType = kDistanceExtent Then
            If SourceHole.FlatBottom = True Then
                'Call TargetHole.SetDistanceExtent(SourceHole.Extent.Distance.value, SourceHole.Extent.Direction, True)
                Call TargetHole.SetDistanceExtent(SourceHole.Extent.Distance.value, TargetHole.Extent.Direction, True)
            Else
                'Call TargetHole.SetDistanceExtent(SourceHole.Extent.Distance.value, SourceHole.Extent.Direction, False, SourceHole.BottomTipAngle.value)
                Call TargetHole.SetDistanceExtent(SourceHole.Extent.Distance.value, TargetHole.Extent.Direction, False, SourceHole.BottomTipAngle.value)
        If SourceHole.ExtentType = kToExtent Then
            Call TargetHole.SetEndOfPart(True)
            Call TargetHole.SetToFaceExtent(SourceHole.Extent.ToEntity.Item(1), SourceHole.Extent.ExtendToFace)
            Call invDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(False)
        If SourceHole.Tapped = True Then
            If SourceHole.TapInfo.FullTapDepth = True Then
                TargetHole.TapInfo = invDoc.ComponentDefinition.Features.HoleFeatures.CreateTapInfo(SourceHole.TapInfo.RightHanded, SourceHole.TapInfo.ThreadType, SourceHole.TapInfo.ThreadDesignation, SourceHole.TapInfo.Class, True)
            Else
                TargetHole.TapInfo = invDoc.ComponentDefinition.Features.HoleFeatures.CreateTapInfo(SourceHole.TapInfo.RightHanded, SourceHole.TapInfo.ThreadType, SourceHole.TapInfo.ThreadDesignation, SourceHole.TapInfo.Class, False, SourceHole.TapInfo.ThreadDepth.value)
        invDoc.Update
    Next
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 22 of 25
GeorgK
Hello Wayne,
your code works in about 80% of the holes. I have to investigate it.
Thanks for your help.
Georg
Message 23 of 25
GeorgK
Hello Wayne,
I could not reproduce the error in every hole type. The best way is to replace the hole by a new one. This process is very stable.
Georg
Message 24 of 25
GeorgK
Hello Wayne,
you wrote:
It seems that if the reference lines are not set for a hole then changing the hole using the API can fail. Below is a screenshot to help explain. Try adding the reference edges to the holes and then running the CopyHoleSettings() code provided by bshbsh in a previous post. In my tests holes without the reference edges will fail but if I add the reference edges the code changes the hole without error.
Is there any workaround to modify the holes when the reference one / two or both are missing?
Is this a bug in the API?
Georg
Message 25 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi George,
Hoping that, workaround is given in the following forum discussion.
https://forums.autodesk.com/t5/inventor-customization/setthroughallextent-hole-klinearplacementtype/...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
