Transfer (get and copy) hole properties to many holes 2019
In Inventor 2019, creating new Preset will help to copy hole settings from one to another as shown below. This should work in part, assembly and API (iLogic, VB.Net)
12 Comments
it wuold be nice to have the button "Copy hole properties" in the Hole dialog box
Tags (3)
GeorgK
This would save a lot of time like in Autocad Mechanical.
GeorgK
Save the settings in a template like in Autocad Mechanical.
this would be great as well!
I think this duplicates existing idea:
https://forums.autodesk.com/t5/inventor-ideas/copy-hole-properties/idi-p/5655082
in R2019 something was done but not very well.
Yijiang.Cai
@GeorgK & @Anonymous, in Inventor 2019, we could consider to edit the target hole feature and save the setting in the hole panel as the preset. So we could use the saved preset for future hole creation. Does it work for you?
GeorgK
@Yijiang.CaiInventor 2019 has some nice new features. But not all of the suggestions are realized like the brush in word to copy the settings.
@Yijiang.Cai, the new hole feature is in the right direction...
I think that the brush is still the best solution.
in any way thank you for your efforts to make Inventor even more close to the designers needs.
inv.ideareview
tracked by [INVGEN-14890]
inv.ideareview
Frank.Schmelzer
Sehr gute Ideen!
eine weitere Idee wäre es die Voreinstellungen in XML - Files zu exportieren, um diese an anderen Arbeitsplätzen für andere User zu importieren
GeorgK
Is there any plan to improve the dialog and add the "brush"?
