copy file to folder
copy file to folder
copy file to folder
Hi all
I am looking for some help to copy a file to a folder.
all the copy methods I have seen state I need to know the path and filename..
I'd simply like to do something like the following and only specify the folder I am copying the file to and not the filename..
copy c:\temp.txt c:\temp2
is it possible folks?
thanks
clutsa
Like this?
Dim app As Inventor.Application = ThisApplication
Dim doc As Document = app.ActiveDocument
doc.SaveAs("C:\temp\" & doc.DisplayName,True)
This will use the same name as the current file but put it in a different drive loc.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
hi @clutsa
I'm actually trying to move/copy some pdf files from one folder to another.
To know which pdf files to move, I use the active document that the rule is  ran from and then I use the first 13 characters of the inventor document filename as a string to search for ( and then use a wildcard after that)
e.g the files may be called
(inventor file = 1234567890abc-something.idw)
(pdf files to move folders)
1234567890abc-some other text.pdf
1234567890abc-some other text 2.pdf
etc... etc.
so I can use the following to trim the inventor filename and then -hopefully- use that (plus a wildcard ) to search the dir for pdf files...
Dim oName As String
oName = Left(oDoc.DisplayName, 13
but how do I move/copy all instances of pdf files  who have the same first 13 characters as the active inventor doc?
thanks for any help
clutsa
This should get you started. This is VBA code so you need to set a reference to "Microsoft Scripting Runtime".
Sub CopyOtherFiles()
Dim app As Application
Dim doc As Document
Set app = ThisApplication
Set doc = app.ActiveDocument
Set FSO = New Scripting.FileSystemObject
DocPath = Left(doc.FullFileName, Len(doc.FullFileName) - (Len(doc.FullFileName) - InStrRev(doc.FullFileName, "\")))
Set MyFolder = FSO.GetFolder(DocPath)
For Each myFile In MyFolder.Files
'    ChangeBack = False
    If Left(myFile.Name, 13) = Left(doc.DisplayName, 13) Then
'        If myFile.Attributes = ReadOnly Then
'            ChangeBack = True
'            myFile.Attributes = Normal
'        End If
        myFile.Copy (DocPath & "New Folder\")
'        If ChangeBack Then myFile.Attributes = ReadOnly
Next
End Sub
I commented out the "read only" code. If you get a message about permission denied try un-commenting that.
