I am getting 5 warnings when attempting to build my solution. It contains Inventor, AutoCAD and Vault references. I haven't changed any code recently, so I'm thinking its due to the updates in the CAD Software. My current builds are Inventor (ver 2019.1.1, build 200) and Vault Professional (ver 2019.1; build 24.1.42.0)
The listed file below has file version 24.1.42.0 (vault.resources), and ilogic.types.resources is 20.0.13800.0
- Warning Assembly 'C:\Program Files\Autodesk\Inventor 2019\Bin\en-US\Autodesk.DataManagement.Client.Framework.Vault.resources.dll' has mismatched identity 'dummy.resources', expected file name: 'dummy.resources.dll'.
- Warning Unable to apply publish properties for item "en-us\autodesk.ilogic.types.resources".
- Warning Assembly 'C:\Program Files\Autodesk\Inventor 2019\Bin\en-US\Autodesk.DataManagement.Client.Framework.resources.dll' has mismatched identity 'dummy.resources', expected file name: 'dummy.resources.dll'.
- Warning Unable to apply publish properties for item "autodesk.ilogic.types".
- Warning Two or more assemblies have the same identity 'dummy.resources, Version=24.1.42.0, Culture=neutral, ProcessorArchitecture=amd64'.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
