メッセージ1/11
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
How to Extract the assembly weight (physical properties mass) into Excel workbook with specific cells address using ilogic rules
解決済! 解決策の投稿を見る。
解決済! 解決策の投稿を見る。
Hi @karram . An example of mass recording in Excel:
Dim sPathExcel As String = "C:\Users\AndriiHumeniuk\Documents\YourExcel.xlsx"
GoExcel.DisplayAlerts = False
GoExcel.Open(sPathExcel, "Sheet1")
GoExcel.CellValue("A1") = String.Concat("", Round((iProperties.Value("Project", "Mass")/1000),2))
GoExcel.Save
GoExcel.Close
Change the placement field and the name of your excel and sheet in it.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Below code works perfectly. Thanks
One more requirements in same concept.
In main assembly, i had many sub assembly and sub parts, For this case how to Extract the particular sub assembly and sub parts weight (physical properties mass) into Excel workbook with specific cells address using ilogic rules.
Hi @karram . You can select components both in the model and in the browser.
Dim oComp As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, _
"Select component...(Press ESC to cancel)")
If oComp Is Nothing Then Exit Sub
Dim oDef As ComponentDefinition = oComp.Definition
Dim oDoc As Document = oDef.Document
Dim oMass As Double = Round(oDoc.PropertySets.Item("Design Tracking Properties").Item("Mass").Value / 1000, 3)
Dim i As Integer = 1
Do While GoExcel.CellValue("A" & i) IsNot Nothing
i += 1
Loop
GoExcel.CellValue("A" & i) = oMass
GoExcel.Save
GoExcel.Close
Without selection i need to use file names (Sub-assembly and sup-parts, for Example) means. how to create?
BR
Karthick
Not sure if I understood you correctly. But this code can record the name and mass of the main assembly and those elements that you choose.
GoExcel.CellValue("A1") = ThisDoc.FileName(False)
GoExcel.CellValue("B1") = String.Concat("", Round((iProperties.Value("Project", "Mass") / 1000), 2))
Dim i As Integer = 2
Do
If oComp Is Nothing Then GoTo SaveExcel
GoExcel.CellValue("A" & i) = oDoc.DisplayName
GoExcel.CellValue("B" & i) = oMass
i += 1
Loop
SaveExcel :
GoExcel.Save
GoExcel.Close
What i means i need mass for particular sub assembly and sub parts into Excel in Main assembly.
For Example as per below image, In main assembly - Always i need Mass for Assy_A, Assy_B, Part_B, Part_D into Excel without any select component function. In my project i used same name for sub assembly and parts.
Hope now i give some clear explanation. Thanks
Thank you for your patience and detailed description, it is really important to understand the question. Because there are many variations of solving the problem. Try this code, please don't forget to enter your components details (line 2).
Dim sListName As New List(Of String) From {"Assy_A", "Assy_B", "Part_B", "Part_D"}
Dim sWriteComp As New List(Of String)
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oOccDef As ComponentDefinition
Dim oOccDoc As Document
Dim oMass As Double
Dim sOccName As String
For Each oOcc As ComponentOccurrence In oDef.Occurrences
sOccName = oOcc.Name.Substring(0, oOcc.Name.IndexOf(":"))
If Not sWriteComp.Contains(sOccName) Then
If sListName.Contains(sOccName) Then
sWriteComp.Add(sOccName)
oOccDef = oOcc.Definition
oOccDoc = oOccDef.Document
oMass = Round(oOccDoc.PropertySets.Item("Design Tracking Properties").Item("Mass").Value / 1000, 3)
GoExcel.CellValue("A" & i) = sOccName
i += 1
End If
End If
Next
GoExcel.Save
GoExcel.Close
Below Code works perfect.
But my requirements is each part and sub assembly paste in Excel with specific cell, we need to define the cell name.
For Example Assy_A as M23 cell, Assy_B as M24 cell, Part_B as C16 cell, Part_D as E16 cell like that. User will define the cell name.
Thanks for your support.
Try this code. Replace the name of your excel - line 2, the names of your components and write their properties in excel. If you don't want information about the main assembly, then comment out lines 8 and 9.
Sub main
Dim sListName As New List(Of String) From {"Assy_A=L5+M5", "Assy_B=L6+M6", "Part_B=L8+M8", _
"Part_D=L10+M10", "Part_C=L1+M1"}
Dim oMass As Double
Dim sOccName, pathName, pathDisc, pathMass, pathMid As String
pathName = GetFullNameAndPath(sListName, sOccName)
If String.IsNullOrEmpty(pathName) Then Continue For
pathMid = pathName.Remove(0, pathName.IndexOf("=") + 1)
pathDisc = pathMid.Substring(0, pathMid.IndexOf("+"))
pathMass = pathName.Remove(0, pathName.IndexOf("+") + 1)
GoExcel.CellValue(pathDisc) = sOccName
GoExcel.CellValue(pathMass) = oMass
i += 1
End If
Next
GoExcel.Save
GoExcel.Close
End Sub
Private Function GetFullNameAndPath(sListName As List(Of String), sOccName As String) As String
For i As Integer = 1 To sListName.Count
If sListName.Item(i - 1).Contains(sOccName) Then Return sListName.Item(i - 1)
Next
Return Nothing
End Function
