Copy all Custom iProperties
kennyj
kennyj
I found this post:
https://forums.autodesk.com/t5/inventor-customization/ilogic-copy-iproperties-formula/td-p/5812353
Where @Balaji_07 provided this snippet:
'--------------Start iLogic Rule "Copy iProperties"
Sub Main()
Dim oCompDoc As Document
Dim oProp As String
Dim oPropSet As PropertySet
oCompDoc = ThisApplication.ActiveDocument
oPropSet = oCompDoc.PropertySets.Item("Inventor User Defined Properties")
iProp = oPropSet.Item("Specification").Expression
iProperties.Value("Custom", "Specifications") = iProp
End Sub
'---------------End iLogic Rule
I want to get ALL of the Custom iProperties, not just one or two as shown above.  Any assistance would be appreciated.
To add to the bonus round; I'd like to actually LINK the Custom iProperties between the derived parts.  From the Idea Stations and other posts, this does not look like it has been solved yet, though...
Thank you in advance,
Kenny Johnson
rjay75
What are you copying them too. Are you just interested in copying from one document to another? Or to newly added iProperties?
kennyj
Thank you, Rodney.
I am trying to copy iProperties from a part file to a part file, or an assembly file to an assembly file.
We have "Library" parts that are either parts or assemblies, derived into part files.  We want to copy the custom properties from the library into the derived parts so that information is available as the parts are used.
Derived parts do not allow you to link/derive iProperties, so I'm trying to automate a copy solution.
Thank you again,
Kenny
HermJan.Otterman
Hello Kenny,
try this code from the derivedcomponent
Dim derivedComponent As Inventor.Document = Thisapplication.ActiveDocument
'if there is only one reference:
Dim referencedComponent As Inventor.Document = derivedComponent.ReferencedDocuments(1)
Dim deriPorps As PropertySet = derivedComponent.PropertySets.Item("Inventor User Defined Properties")
Dim refiProps As PropertySet = referencedComponent.PropertySets.Item("Inventor User Defined Properties")
Dim oProp As Inventor.Property
For Each oProp In refiProps
Try
deriPorps.Add(oProp.Value, oProp.Name)
Catch ex As Exception
deriPorps.Add(oProp.Value)
End Try
Next
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
kennyj
@HermJan.Otterman,
This worked like a charm.  Thank you for your assistance.
Kenny
