iLogic copy iProperties formula
Hi!
Did not find any answers to this one, but it should be easy?
I want to copy one iProperty to another, but I want to copy the formula, not the text.
This one copies only the text. i want to copy this: =<DimX> x <DimY> t=<DimZ>
SyntaxEditor Code Snippet
iProperties.Value("Custom", "Specification") = iProperties.Value("Custom", "SpecificationItem")
 /Nickolas
Balaji_07
Hi Nickolas,
Refer the below link for the answer..
http://modthemachine.typepad.com/my_weblog/2010/04/iproperty-expressions.html
Cheers 🙂
Balaji A
Accept this post as Solution if  you found it usefull and do not forget to hit Kudos! Smiley Wink
I have tried to use the examples in inventor iLogic, but with no success, im not that good at the API...
As in the picture, I want the expression (=<DimX> x <DimY> t=<Thickness>) to be copied, not the value (1757 x 230,7 t=1,5).
btw, using Inventor 2014
Balaji_07
Hi Nickolas,
I have not noticed that you are using ilogic..
The below ilogic code snippet will work!
Use your iProperties, I have used some dummy iProperties(Specification, Specifications). NJoy 🙂
Sub Main()
Dim oCompDoc As Document
Dim oProp As String
Dim oPropSet As PropertySet
oCompDoc = ThisApplication.ActiveDocument
oPropSet = oCompDoc.PropertySets.Item("Inventor User Defined Properties")
iProp = oPropSet.Item("Specification").Expression
iProperties.Value("Custom", "Specifications") = iProp
End Sub
Balaji A
Whoho!
looks good, will test it on monday, right now the beer is more alluring then iLogic 😉
