Coppy rules to all Parts / Sub-assemblies which dont have rule before.
tamnn.designer
tamnn.designer
Hi Sir,
I have old projects which don't have any rules before. Now i want to use external Rule to copy all rule into all children part and all sub-assembly as the pictures above.
Many thanks and best regards.
Andrii_Humeniuk
Hi @tamnn.designer . Try this code that I took here and modified a bit.
Sub Main
	Dim copyFrom As AssemblyDocument = ThisDoc.Document
	For Each copyTo As Document In copyFrom.AllReferencedDocuments
		If copyTo.IsModifiable Then
			'Copy the rules
			CopyRules(copyFrom, copyTo)
			'Copy the Event triggers
			CopyEventsPropSet(copyFrom, copyTo)
			'Save
			copyTo.Save()
		End If
	Next
End Sub
Sub CopyRules(CopyFrom As Document, CopyTo As Document)
	For Each oRule As iLogicRule In iLogicVb.Automation.Rules(CopyFrom)
		Dim oCopy As iLogicRule = iLogicVb.Automation.AddRule(CopyTo, oRule.Name, "")
		oCopy.Text = oRule.Text
	Next
End Sub
Sub CopyEventsPropSet(CopyFrom As Document, CopyTo As Document)
	Dim oPropSet As Inventor.PropertySet = CopyFrom.PropertySets("{2C540830-0723-455E-A8E2-891722EB4C3E}")
	Try
		CopyTo.PropertySets("{2C540830-0723-455E-A8E2-891722EB4C3E}").Delete()
	Catch
	End Try
	Dim newPropSet As Inventor.PropertySet = CopyTo.PropertySets.Add("_iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
	For Each prop As Inventor.Property In oPropSet
		newPropSet.Add(prop.Value, prop.Name, prop.PropId)
	Next
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
tamnn.designer
Hi sir,
can you show me the where is the line to choose the template file to coppy into all part and sub-assembly ?
Andrii_Humeniuk
The code I wrote for you copies the rules from the main assembly to sub-assemblies and parts. In the code that I referred to in the previous message, you can choose the file from which you copy and the file to which you copy rules.
So in the link it's line 2 for the file you're copying from and line 3 for the file you're copying to.
