convert Inventor dwg to Autocad dwg problem?
Hi!
i'm usin the code bellow to convert a inventor dwg to a Autocad dwg, but a error is diplayed in the line:
"If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then"
the error displayed is:
-run time error '424':
object required
can someone tell me what is wrong here?
thanks.
Public Sub PublishDWG()
' Get the DWG translator Add-In.
Dim DWGAddIn As TranslatorAddIn
Set DWGAddIn =
ThisApplication.ApplicationAddIns.ItemById("{C24E3 AC2-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslation Context
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMa p
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
Dim strIniFile As String
strIniFile = "C:\temp\Test.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oDataMedium.FileName = "c:\temp\dwgout.dwg"
'Publish document.
Call DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
