DockableWindow
DockableWindow
Message 1 of 10
DockableWindow
 Hi! I have a problem with my DockableWindow. I have designed it as userControl and load it with show.
And now I want to use the Inventor Shortcuts for example return but it seems as they are locked by inventor.
If I'm watching the KeyDown Event to on a Textboxcontrol I didn't get the event fired while pressing return. Is there an other way to turn off the ShortCuts.
Thanks a lot
Kind Regards
Bernhard
Replies (9)
Message 2 of 10
jeff.pek
There were issues here that got fixed before Inventor 2011 released. So, the should just work now.
Is there a way that you can post your project?
Jeff
Message 3 of 10
Hi
I'm using AIP 2011 and WinXP SP3 and I'm still having this problem!?
here's my loading code for the uc:
private Inventor.DockableWindow dw;
private Tools.WorkDirBrowser.ucWorkDir dwc;
dw = m_inventorApplication.UserInterfaceManager.DockableWindows.Add(GlobalData.ID, "WorkDirControl", "Work Directory");
dwc = new Tools.WorkDirBrowser.ucWorkDir();
dw.AddChild(dwc.Handle);
dwc.Show();
dw.SetMinimumSize(100, 100);
dw.DockingState = DockingStateEnum.kDockLastKnown;
dw.Visible = true;
 and in the usercontrol I'm only using one Textbox to test it!
Thanks a lot
Bernhard
Message 4 of 10
jeff.pek
Hi Bernhard -
I'm not able to reproduce this. Here's a simple test add-in (in C#) that does something similar to what you're doing. Can you see if this works for you?
The project doesn't auto-register; you'll need to do that manually with regasm.
Jeff
Message 5 of 10
Hi Jeff,
Maybe it is because you are using a Form an not a Usercontrol!
Because in My code  the property "private Tools.WorkDirBrowser.ucWorkDir dwc;" is a usercontrol!
So I'm going to try it with a form!
Many ThanksSmiley Very Happy
Bernhard
Message 6 of 10
Hi Jeff,
you are right! When I'm using a form I don't have problems with the return button! But!!!!
I've added a listviewcontrol and a Toolstrip! When I'm using the toostrip I have no problem! Entering the Listview the Dockable window loses it's focus and when I'm trying to use the toolbar again It doesn't work. I have to click on the Dockable Window (activate ) and then it works with the toolstrip again!
Sorry I don't want to post my whole project!
Bernhard
Message 7 of 10
jeff.pek
Hmmm. I see this same thing in a test project I made up. Not quite sure why this is happening.
I'll tinker around a bit.
We have definitely seen some interaction problems between .NET controls and Inventor; I'm not sure if this falls into that category; it seems of a different type.
Jeff
Message 8 of 10
jeff.pek
Hi again, Bernhard -
I think I found a partial solution to the toolstrip button issue. See the following article:
  http://blogs.msdn.com/b/rickbrew/archive/2006/01/09/511003.aspx
I verified that this worked in my test project.
I do notice that the button tooltips are still not showing unless you activate some other window, but that's a minor issue.
Jeff
Message 9 of 10
Hi Jeff,
many thanks for your help, but I'm using a Toolstrip (in my VS2005 project) as BreadCrumbbar and it doesn't work!
I've also tried this
http://stackoverflow.com/questions/2423234/make-a-form-not-focusable-in-c
But it makes no difference?
I don't know! And in the API Help is no really good sample!?
Thanks a lot!!
Bernhard
Message 10 of 10
jeff.pek
Hi again Bernhard. I'm not sure what to tell you.
If you want to send me your project, perhaps I can take a look and figure something out.
You can reach me at <first>.<last>@autodesk.com
Jeff
