Convert IntersectionCurve into a path I can find start / stop points and params
johnPGNFG
johnPGNFG
Hi all!
Is there a way to treat an intersection curve similar to an edge?  For example, an edge you can use edge.Evaluator.GetParamExtents(.....) and edge.StartVertex.  I need to find these values but the only way I have found to do this is by checking the sketchEntity3d.Type in each intersection curve and then casting the sketchEntity3d to that type.  This is a problem because I can have multiple Types and I need to keep all the entities in the same list.  Below I'm only finding sketchSpline3d types.  Is there a generic type that I can make each entity?  Or is there a way to force the entity to be a spline regardless of the type? It seems like there's a way to convert the intersection curve into some kind of path that I can extract the data from.  I tried converting it to a ProfilePath3d and Path but to no prevail.
Sketch3D sketch3d = oCompDef.Sketches3D.Add();
IntersectionCurves iCurves = sketch3d.IntersectionCurves;
List<SketchSpline3D> sketchSplineList = new List<SketchSpline3D>();
SketchSpline3D spline = null;
foreach (IntersectionCurve intersectCurve in iCurves)
       foreach (SketchEntity3D sketchInt in intersectCurve.SketchEntities)
           if (sketchInt.Type  == ObjectTypeEnum.kSketchSpline3DObject)
                spline = (SketchSpline3D)sketchInt;
                sketchSplineList.Add(spline);
Michael.Navara
All relevant geometries (except sketchPoints and maybe something else) has oSketchEntity3D.Geometry.Evaluator property of type CurveEvaluator
From this object you can get param extents, point at param, etc.
johnPGNFG
When I use oSketchEntity3D.Geometry.Evaluator, Geometry is not recognized and says "SketchEntity3D does not contain a definition for Geometry...". Am I missing something?
Michael.Navara
Yes, I'm sorry. You use C# instead of iLogic.
In this case you need to use "late binding" to obtain Geometry from SketchEntity3D.
Use dynamic type
CurveEvaluator GetCurveEvaluator1(SketchEntity3D sketchEntity3D)
    dynamic sketchEntityDynamic = sketchEntity3D;
    try
        return sketchEntityDynamic.Geometry.Evaluator;
    catch
        return null;
Use late binding directly using InvokeMember
CurveEvaluator GetCurveEvaluator2(SketchEntity3D sketchEntity3D)
    try
        var geometry = sketchEntity3D.GetType().InvokeMember("Geometry", BindingFlags.GetProperty, null, sketchEntity3D, null);
        var evaluator = geometry.GetType().InvokeMember("Evaluator", BindingFlags.GetProperty, null, geometry, null);
        return evaluator as CurveEvaluator;
    catch
        return null;
Sample usage
public override void Main()
    var pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketch3DCurveFilter, "Pick curve");
    var sketchEntity3D = pick as SketchEntity3D;
    CurveEvaluator curveEvaluator1 = GetCurveEvaluator1(sketchEntity3D);
    CurveEvaluator curveEvaluator2 = GetCurveEvaluator2(sketchEntity3D);
    Logger.Debug((curveEvaluator1 != null).ToString());
    Logger.Debug((curveEvaluator2 != null).ToString());
iLogic/VB.NET does it for you automatically.
johnPGNFG
Thank you! That works perfectly
