Auto select face of washer to constraint when placed in an assembly (similar to content center)
phani.gampala
phani.gampala
Hello everyone,
I'm trying to place a set of fasteners into assembly using ilogic code. I'm not a programmer but can understand codes and write basic ones.
WHAT THE CODE DOES:
With the inputs from this forum I have written a code that places a set of fasteners (bolt, flat washer and spring washer) from content center and constraint them together and then constarint them to a hole by picking faces with the mouse selection.
The code can also create a pattern if the hole it is constrained to is part of a feature pattern.
WHAT I NEED TO ADD:
1. I need the code to auto select the faces of the washer and only place the washer after selecting the faces of the hole just like content center works with individual parts, I need to achieve it with a set.
2. At the least, if the above is complicated, I need the parts to be placed where I click my mouse so that I dont have to find them in an assembly.
Any help is much appreciated. Thank for all the help I have already received from this forum...
oApp = ThisApplication
Dim oDoc As Document = oApp.ActiveDocument
Dim oCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oAllOcc As ComponentOccurrences
Dim oOcc As ComponentOccurrence
Dim oCompDef1 As ComponentDefinition
Dim oCompDef2 As ComponentDefinition
Dim oPart1 As ComponentOccurrence
Dim oPart2 As ComponentOccurrence
'Adding and Constraining the fasteners...
'It is important to leave the browser name blank "" so that new instances are named in increments.
'Also instead Of mentioning the browser name of the Constraint while adding the Constraint mention it As Component.Name,
'so that a New Constraint Is created For every instance...
SelectSet = InputListBox("Select Fastener set", MultiValue.List("SelectSet"), SelectSet, Title := "Select Set")
If SelectSet = "" Then Exit Sub
Select Case SelectSet
Case "Xtie"
While True
XtieBoltSize = InputListBox("Select M10 Bolt Size", MultiValue.List("XtieBoltSize"), XtieBoltSize, Title := "XtieBolts")
If XtieBoltSize = "" Then Exit While
Components.ContentCenterLanguage = "en-US"
Dim Component1 = Components.AddContentCenterPart("", "Fasteners:Washers:Plain", "SS Flat Washers",
                                                 {"STOCK_TYPE","S","NND","10"},
                                                 position := Nothing, grounded := False,
                                                 visible := True, appearance := Nothing)
Dim Component2 = Components.AddContentCenterPart("","Fasteners:Washers:Spring","SS Spring Washers",
Constraints.AddMate("", Component1.Name, "Work Axis1", Component2.Name, "Work Axis1",
                    offset := 0.0, e1InferredType := InferredTypeEnum.kNoInference, e2InferredType := InferredTypeEnum.kNoInference,
                    solutionType := MateConstraintSolutionTypeEnum.kNoSolutionType,
                    biasPoint1 := Nothing, biasPoint2 := Nothing)
Constraints.AddMate("", Component1.Name, "YZ PLANE", Component2.Name, "YZ PLANE",
Select Case XtieBoltSize
Case "M10x25"
Dim Component3 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M10","NLG","25"},
Constraints.AddMate("", Component3.Name, "X Axis",
                     Component2.Name, "X Axis",
                     solutionType := MateConstraintSolutionTypeEnum.kOpposedSolutionType)
                     "YZ Plane", Component2.Name, "YZ Plane",
                     2.35 mm)
Case "M10x30"
Dim Component4 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M10","NLG","30"},
Constraints.AddMate("", Component4.Name, "X Axis",
                     2.35 mm)
Case "M10x35"
Dim Component5 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M10","NLG","35"},
Constraints.AddMate("", Component5.Name, "X Axis",
                     2.35 mm)
Case "M10x40"
Dim Component6 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M10","NLG","40"},
Constraints.AddMate("", Component6.Name, "X Axis",
                     2.35 mm)
Case "M10x45"
Dim Component7 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","NS","SIZE_SEL","M10","NLG","45"},
Constraints.AddMate("", Component7.Name, "X Axis",
					 2.35 mm)
End Select
oDoc.Update '
End While
Case "RR"
While True
RRBoltSize = InputListBox("Select M8 Bolt Size", MultiValue.List("RRBoltSize"), RRBoltSize, Title := "Title", ListName := "List")
If RRBoltSize = "" Then Exit While
Dim Component8 = Components.AddContentCenterPart("", "Fasteners:Washers:Plain", "SS Flat Washers",
                                                 {"STOCK_TYPE","S","NND","8"},
Dim Component9 = Components.AddContentCenterPart("","Fasteners:Washers:Spring","SS Spring Washers",
Constraints.AddMate("", Component8.Name, "Work Axis1", Component9.Name, "Work Axis1",
Constraints.AddMate("", Component8.Name, "YZ PLANE", Component9.Name, "YZ PLANE",
Select Case RRBoltSize
Case "M8x16"
Dim Component10 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M8","NLG","16"},
Constraints.AddMate("", Component10.Name, "X Axis",
                     Component9.Name, "X Axis",
                     "YZ Plane", Component9.Name, "YZ Plane",
                     2.1 mm)
Case "M8x20"
Dim Component11 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M8","NLG","20"},
Constraints.AddMate("", Component11.Name, "X Axis",
                     2.1 mm)
Case "M8x25"
Dim Component12 = Components.AddContentCenterPart("", "Fasteners:Bolts:Hex Head", "SS HEX HEAD SET SCREWS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M8","NLG","25"},
Constraints.AddMate("", Component12.Name, "X Axis",
                     2.1 mm)
End Select
oDoc.Update '
End While
Case "Wstrip"
While True
WSFasteners = InputListBox("Select M5 SS CSK Size", MultiValue.List("WSFasteners"), WSFasteners, Title := "Title", ListName := "List")
If WSFasteners = "" Then Exit While
Dim Component13 = Components.AddContentCenterPart("", "Fasteners:Washers:Plain", "SS Flat Washers",
                                                 {"STOCK_TYPE","S","NND","5"},
Dim Component14 = Components.AddContentCenterPart("","Fasteners:Nuts:Flanged & Nyloc","SS Nyloc Nuts",
                                                 {"STOCK_TYPE","S","SIZE_SEL","5"},
Constraints.AddMate("", Component13.Name, "Work Axis1", Component14.Name, "Work Axis1",
Constraints.AddMate("", Component13.Name, "YZ PLANE", Component14.Name, "YZ PLANE",
Select Case WSFasteners
Case "M5x12"
Dim Component15 = Components.AddContentCenterPart("", "Fasteners:Bolts:Countersunk", "SS CSK SHCS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M5","NLG","12"},
Constraints.AddMate("", Component15.Name, "Z Axis",
                     Component14.Name, "X Axis",
                     "XY Plane", Component14.Name, "YZ Plane",
                     -7 mm)
Case "M5x16"
Dim Component16 = Components.AddContentCenterPart("", "Fasteners:Bolts:Countersunk", "SS CSK SHCS",
                                                 {"STOCK_TYPE","S","SIZE_SEL","M5","NLG","16"},
Constraints.AddMate("", Component16.Name, "Z Axis",
                     -10 mm)
End Select
oDoc.Update
End While
End Select
Dim oHole1 As Face 'first hole (proxy hole) is the cylindrical face/axis of our fastener...
oHole1 = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Pick Bolt/Washer Cylindrical Face, Press Esc to cancel")
If oHole1 Is Nothing Then Exit Sub 'exit rule if esc button is pressed...
oPart1 = oHole1.ContainingOccurrence 'our part is the part that contains the hole we selected with the mouse (the fastener)...
Dim oFP1 As FaceProxy 'For parts in the assembly we need to define proxy faces as it could any part and a specific part cannot be mentioned...
oPart1.CreateGeometryProxy(oHole1, oFP1) 'FP1 is the proxy feature for oHole1...
Dim oHole2 As Face
oHole2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Pick Part Hole Face, Press Esc to cancel")
If oHole2 Is Nothing Then Exit Sub
oPart2 = oHole2.ContainingOccurrence
Dim oFP2 As FaceProxy
oPart2.CreateGeometryProxy(oHole2, oFP2)
Dim oConstraint1 As AssemblyConstraint = oCompDef.Constraints.AddMateConstraint(oFP1, oFP2, "0", InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine)
'Mate constraint between axis...
oDoc.Update
Dim oFace1 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick Washer Face. Press Esc to cancel")
If oFace1 Is Nothing Then Exit Sub
Dim oFace2 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick Part face. Press Esc to cancel")
If oFace2 Is Nothing Then Exit Sub
oCompDef.Constraints.AddMateConstraint(oFace1, oFace2, "0") 'Mate constraint between faces...
oDoc.Update '
Dim oFeature As PartFeature
oFeature = oFP2.CreatedByFeature '
oFeature.Name = oFP2.CreatedByFeature.Name
oCompDef2 = oFeature.Parent
Dim oPF As PartFeature
Dim oPartFeatures As PartFeatures = oCompDef2.Features
Dim oFeature1 As PartFeature' oFeature1 is the pattern part feature required
Dim oProxyFeature1 As Object 'oProxyFeature1 will be the proxy of oFeature1...
Dim oProxyFeature2 As Object 'oProxyFeature2 will be the proxy of oFeature...
'Creating a collection...
Dim oTO As TransientObjects = ThisApplication.TransientObjects
Dim oComps As ObjectCollection = oTO.CreateObjectCollection
Dim oComp As Object
Dim Highlight As HighlightSet = oDoc.HighlightSets.Add()
Highlight.Color = oTO.CreateColor(0,75,255,0.2)
'If the parent hole/first hole is selected in a pattern...
If oFeature.Type = kHoleFeatureProxyObject Or oFeature.Type = kCutFeatureProxyObject Or oFeature.Type = kExtrudeFeatureObject Then
For Each oPF In oPartFeatures
If oPF.Type = kCircularPatternFeatureObject Then
If oFeature.Name = oPF.ParentFeatures.Item(1).Name Then
oFeature1 = oPF 'Assigning the pattern feature to a variable. In this case circular pattern...
If oPF.Type = kRectangularPatternFeatureObject Then
Next
oCompDef.Occurrences.AllReferencedOccurrences(oCompDef2).Item(1).CreateGeometryProxy(oFeature1, oProxyFeature1)
Highlight.AddItem(oProxyFeature1)
Dim oPattern As MsgBoxResult = MessageBox.Show("Pattern components?", "", MessageBoxButtons.YesNo)
If oPattern = vbYes Then
'Loop for selecting components that need to be added to the collection...
While True
oComp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select the Components. Esc to Continue.")
If oComp Is Nothing Then Exit While
oComps.Add(oComp)
Highlight.AddItem(oComp)
End While
oCompDef.OccurrencePatterns.AddFeatureBasedPattern(oComps, oProxyFeature1)
Else
'oFeature is created by a pattern in the part. So, ofeature id already the feature pattern...
Dim oFirstHole As PartFeature = oFeature.ParentFeatures.Item(1)
Dim oFirstFace As FaceProxy = oFirstHole.Faces.Item(1)
oConstraint1.Delete
Dim oConstraint2 As AssemblyConstraint =  oCompDef.Constraints.AddMateConstraint(oFP1, oFirstFace, "0", InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine)
oDoc.Update
oCompDef.Occurrences.AllReferencedOccurrences(oCompDef2).Item(1).CreateGeometryProxy(oFeature, oProxyFeature2)
Highlight.AddItem(oProxyFeature2)
Dim oPattern As MsgBoxResult = MessageBox.Show("Pattern components?", "",MessageBoxButtons.YesNo)
While True
oComps.Add(oComp)
End While
oCompDef.OccurrencePatterns.AddFeatureBasedPattern(oComps, oProxyFeature2)
Else If oPattern = vbNo Then
oConstraint2.Delete
oConstraint1 = oCompDef.Constraints.AddMateConstraint(oFP1, oFP2, "0", InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine)
Curtis_Waguespack
Hi @phani.gampala
I'm short on time to reply to your example code, but there is an example file set at this link that might give you some ideas on how to proceed:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/place-component-gt-activate-insert-m...
I hope this helps.
Curtis
phani.gampala
Thank you for the response @Curtis_Waguespack
I have seen your code before while I was searching for a solution. I must admit I did not understand all of it. Also, I think the difference is that I have multiple washers that can be placed based on a selection from a input list box whereas in your code it is the same part. If you have time to go through my code please let me know what I'm missing whenever you can. I will try to figure out a way in the mean time.
