CONVERT ILOGIC TO IASSEMBLY
Message 1 of 1
I have a ilogic assembly that replaces parts depending on the rule..24.00 x 24.00 door has some of the same parts as an 24.00 x 30.00 door.
The issue I am having is using 2 different sizes in the same assembly (2ea 24.00 x 24.00 and 2ea 24.00 x 30.00 doors).
Since the are based off the same assembly model it wants to change all the doors to the same rule size.
Is there a way to have a ilogic assembly place assemblies without having to give each new assembly a new number.
These are standard assemblies and have existing file names.
The only way I can think of doing this is with iassemblies, if so can i use the exising assemblies in ilogic to create these in a iassembly.
Steven
Replies (0)
