Conversion from string to type 'Double" is not valid
blucas0325
Message 1 of 12
blucas0325
I have an iLogic Rule that is tied to a Custom "Form" assembly. This has been working for year but recently we upgraded to Inventor 2023 and I am now getting an error when I try to use it.
I am getting a "Conversion from string "value" to type 'Double' is not valid" error message. I have done some searching and it sounds like I need to incorporate a "CDbl()" but I am not familiar enough with this to know how it should be setup.
Here is my iLogic rule:
LENGTH = RoundToFraction(Length_ID, 1 / 16, RoundingMethod.Round)
WIDTH = RoundToFraction(Width_ID, 1/16, RoundingMethod.Round)
DEPTH = RoundToFraction(Height_ID, 1/16, RoundingMethod.Round)
L = RoundToFraction(LENGTH, 1/16, RoundingMethod.Round)
W = RoundToFraction(WIDTH, 1/16, RoundingMethod.Round)
D = RoundToFraction(DEPTH, 1/16, RoundingMethod.Round)
iProperties.Value("Custom", "Item #")=ITEMNUMBER
iProperties.Value("Project", "Description")=NAME & "," & " " & L & " X " & W & " X " & D
iProperties.Value("Custom", "EXPORT")=PARTNUMBERorPKGNUMBER
iProperties.Value("Summary", "Title") = NAME
iProperties.Value("Custom", "DESIGN STATUS") = DESIGN_STATUS
iProperties.Value("Custom", "CUSTPN") = CUSTPN
iProperties.Value("Custom", "PKG") = PKG
 Could someone give me a hand and point me in the right direction?
Thank you in advance!
Replies (11)
Message 2 of 12
abdullah_elq
Which line of code does your error pop-up mention?
Message 3 of 12
blucas0325
Line 1 & Line 2
Message 4 of 12
blucas0325
@abdullah_elq it is line 1 & 2
Message 5 of 12
Frederick_Law
What is the  value of Length_ID and Width_ID?
Program could fail if they're empty or not numeric.
Message 6 of 12
blucas0325
@Frederick_Law the values will be in decimal form. Below is a screenshot of the Form dialog window that we use to input the values.
Message 7 of 12
abdullah_elq
Try this:
LENGTH = RoundToFraction(CDbl(Length_ID), 1 / 16, RoundingMethod.Round)
Message 8 of 12
blucas0325
@abdullah_elq - that didn't work. Got the same error message. Below is a screenshot of the error message tabs.
Message 9 of 12
Frederick_Law
It cannot convert fraction string to number.
Message 10 of 12
Curtis_Waguespack
Hi @blucas0325
Maybe something like this.
I hope this helps.
Curtis
imports System.Text.RegularExpressions
wholeNum = CDec(Math.Truncate(Length_ID))
decNum = Length_ID - wholeNum
fraction = RoundToFraction(decNum, 1 / 16, RoundingMethod.Round)
'convert rounded fraction back to decimal
Dim div = Regex.Replace(fraction, "(\d+)/(\d+)", Function(m) Decimal.Parse(m.Groups(1).Value / Decimal.Parse(m.Groups(2).Value)))
LENGTH = wholeNum + div
L = RoundToFraction(LENGTH, 1 / 16, RoundingMethod.Round)
msgbox(L)
Message 11 of 12
Frederick_Law
LENGTH = Length_ID - (Length_ID MOD 0.0625)
Message 12 of 12
blucas0325
@Frederick_Law That worked! Thank you!
