Controlling Vault Options Through iLogic
Is there a way to control the Vault Options (actually the prompts) through iLogic? I have tried SilentOperation - that makes the Inventor prompts not appear but it doesn't suppress the Vault Prompts.
rjay75
So that you were on the vault options.
The Vault may or may not obey silent operation as it is just an add in itself.
So outside of it's prompts window there not a lot from iLogic that you can do about vault prompts.
I've played around a bit... is it possible to enable/disable add-ins through iLogic? I am trying to automate process without the user having to click a bunch of buttons on the prompts. Could I turn the Vault add-in off during a section of code and turn it back on later? Again, I'd like to do this through iLogic so the user doesn't have to do anything except run the rule.
