- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I have a challenge. In my assembly I use different joints. My question is specifically about the cylindrical joint. I know you can specify an angle at the limits. That also works well. Now I want to control the angle using iLogic. Depending on which option it is, you can do/see something:
option 1: 90 deg
option 2: 180deg
option 3: free to move between 90 and 180 degrees
After a search I only came across code to supress the joint. So that's not what I'm looking for. Someone who can help me?
