Control PositionalRepresentations and LevelOfDetail
GeorgK
Advisor Advisor
GeorgK
Hello together,
I am looking for a possibility to control the PositionalRepresentations and LevelOfDetail. If I choose number one (01_ text varies ) of the PositionalRepresentations the LevelOfDetail should switch to 01_XXXX.
I found a peace of could that switches but the names must be equal.
http://forums.autodesk.com/t5/Inventor-Customization/Control-Positional-Reps-With-ILogic/td-p/476918...
Is it possible to modify the code to do that?
Thank you very much
Georg
philippe.leefsma
Hi Georg,
You could use the "RepresentationEvents.OnActivatePositionalRepresentation" to get notified when a positional rep is activated, based on that you could change the LOD from API:
LevelOfDetailRepresentation.Activate
Sub LoD()
    Dim doc As AssemblyDocument
    Set doc = ThisApplication.ActiveDocument
    Dim mng As RepresentationsManager
    Set mng = doc.ComponentDefinition.RepresentationsManager
    Dim LoDs As LevelOfDetailRepresentations
    Set LoDs = mng.LevelOfDetailRepresentations
    LoDs.item("MyLoD").activate
    doc.Rebuild
    ' Create a new level of detail.
    Dim oLODRep As LevelOfDetailRepresentation
    Set oLODRep = LoDs.Add("My LOD")
    ' Suppress an occurrence.
    doc.ComponentDefinition.Occurrences.item(1).Suppress
    ' Save the document, which is really saving the LOD.
    ThisApplication.ActiveDocument.Save
    ' Activate the master LOD.
    mng.LevelOfDetailRepresentations.item("Master").activate
End Sub
 Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
