Context menu separator
JoAntt
JoAntt
Hi
Does anyone know how to add a separator to the context menu.
Im Using vb.net
marcin_otręba
Hi, in context or linear menu ? because in context i afraid it is not possible.
In linearmenu you can use:
Inventor 2025 Help | CommandControls.AddSeparator Method | Autodesk
        Private Sub OnLinearMarkingMenu(ByVal SelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum,
                                      ByVal LinearMenu As CommandControls, ByVal AdditionalInfo As Inventor.NameValueMap) Handles oUserInputEvents.OnLinearMarkingMenu
            For Each control As CommandControl In LinearMenu
                If control.InternalName = "DrawingAddRowToRevisionTableCtxCmd" Then
                    Try
                        Call LinearMenu.AddSeparator(control, False)
                    Catch ex As Exception
                    End Try
                End If
            Next
       End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
