CONTENT CENTER - NEED TO FILTER CONTENT CENTER PARTS FROM THE REMAINING COMPONEN
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I am assigning iPrperties and assembly tree browser display names to the components in my assembly. Essentially, in this process I need to leave alone the content center parts.
I request help on some ilogic coding to filter content center parts.
Thanks.
wayne.brill
This DevBlog post shows a way using the Inventor API.
http://adndevblog.typepad.com/manufacturing/2012/06/determine-whether-a-part-is-a-content-center-par...
PartComponentDefinition.IsContentMember
Let me know if you have trouble using this in an iLogic rule.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
RoyWickrama_RWEI
Hi Wayne;
Thanks for the reply. As I am not a so good programming guy, I can't create useful coding by reading it. however, in order to get my work going on, I tried with the LOD (all content center suppressed) and running the rule as shown below:
If Component.IsActive(oComp.Name) = True Then
End If
It is good for now: will explore your solution too.
Roy Wickrama
