Constrains animation ad iLogic
mirko.saiani
mirko.saiani
I have a constrain (angle) where d_vin = 0° is the angle to start ma drive animation.
I want to make a role where is d_vin > 15 to
MessageBox.Show ("hello HOME!")
But when I use drive constrain d_vin doesn't change ....
can you help me?
thank
mirko
mirko.saiani
Maybe it's non clear my problem?
theo.bot
I think you need to explain a little bit more about what you have and what your want. 😉
mirko.saiani
I thought it was easy ... but only in my mind 😀
I have two pieces with a constraint
mirkosaiani_1-1637919034485.png where d2 is the angle
I made this roule:
iLogicVb.UpdateWhenDone = True
MessageBox.Show (d2)
If d2 > 20
  d2 = 0
  MessageBox.Show("bla bla bla", "bla bla bla", MessageBoxButtons.OK, MessageBoxIcon.Error)
I try to animate the constraint
when the angle is >20 I havent the MessageBox ... how can i do?
thanks!
mirko
theo.bot
When you use drive constrain, you can't get an update of the parameter (or affected parameter) values. But instead of using drive constrain, you can also drive a parameter with a small loop.
