Constrain two parts in subassembly from an assembly
Hello everybody,
I am trying to constraint two work plan of two part ( Pièce:1 and Pièce2:1) inside a the subassembly (Test:1):
When I open "Test:1" like this:
I select in Inventor the two parts and I launch this code and it is working:
Public Sub TestSub1()
Dim oMainAsmDoc As AssemblyDocument
Set oMainAsmDoc = ThisApplication.ActiveDocument
Dim oSelectedObject As ComponentOccurrence
Dim oSelectedObject2 As ComponentOccurrence
Set oSelectedObject = oMainAsmDoc.SelectSet.Item(1)
Set oSelectedObject2 = oMainAsmDoc.SelectSet.Item(2)
Dim oSelectedObjectPlaneYZ As WorkPlane
Dim oSelectedObject2PlaneYZ As WorkPlane
Set oSelectedObjectPlaneYZ = oSelectedObject.Definition.WorkPlanes.Item(1) 'YZ
Set oSelectedObject2PlaneYZ = oSelectedObject2.Definition.WorkPlanes.Item(1) 'YZ
Dim oSelectedObjectPlaneYZProxy As WorkPlaneProxy
Dim oSelectedObject2PlaneYZProxy As WorkPlaneProxy
Call oSelectedObject.CreateGeometryProxy(oSelectedObjectPlaneYZ, oSelectedObjectPlaneYZProxy)
Call oSelectedObject2.CreateGeometryProxy(oSelectedObject2PlaneYZ, oSelectedObject2PlaneYZProxy)
ShowProxyPath oSelectedObjectPlaneYZ
ShowProxyPath oSelectedObjectPlaneYZProxy
Set Contraintes = oMainAsmDoc.ComponentDefinition.constraints
Call Contraintes.AddMateConstraint(oSelectedObject2PlaneYZProxy, oSelectedObjectPlaneYZProxy, 50)
End Sub
But now when I am in the context of "Ensemble1:1" like the first picture when I launch the code it doesn't work because I don't have created the geometry proxy to the top assembly.
I tried like this :
Public Sub TestSub3()
Dim oAssemblyLevel0 As AssemblyDocument
Set oAssemblyLevel0 = ThisApplication.ActiveDocument
Dim oSelectedObjectLevel2 As ComponentOccurrence
Dim oSelectedObject2Level2 As ComponentOccurrence
Set oSelectedObjectLevel2 = oAssemblyLevel0.SelectSet.Item(1)
Set oSelectedObject2Level2 = oAssemblyLevel0.SelectSet.Item(2)
Dim oSelectedObjectLevel2PlaneYZ As WorkPlane
Dim oSelectedObject2Level2PlaneYZ As WorkPlane
Set oSelectedObjectLevel2PlaneYZ = oSelectedObjectLevel2.Definition.WorkPlanes.Item(1) 'YZ
Set oSelectedObject2Level2PlaneYZ = oSelectedObject2Level2.Definition.WorkPlanes.Item(1) 'YZ
Dim PlaneYZForProxyForLevel1 As WorkPlaneProxy
Dim Plane2YZForProxyForLevel1 As WorkPlaneProxy
Call oSelectedObjectLevel2.CreateGeometryProxy(oSelectedObjectLevel2PlaneYZ, PlaneYZForProxyForLevel1)
Call oSelectedObject2Level2.CreateGeometryProxy(oSelectedObject2Level2PlaneYZ, Plane2YZForProxyForLevel1)
Set oAssemblyLevel1 = oAssemblyLevel0.ComponentDefinition.Occurrences.ItemByName("Test:1")
Dim PlaneYZProxyForLevel0 As WorkPlaneProxy
Dim Plane2YZProxyForLevel0 As WorkPlaneProxy
Call oAssemblyLevel1.CreateGeometryProxy(PlaneYZForProxyForLevel1, PlaneYZProxyForLevel0)
Call oAssemblyLevel1.CreateGeometryProxy(Plane2YZForProxyForLevel1, Plane2YZProxyForLevel0)
Set Contraintes = oAssemblyLevel0.ComponentDefinition.constraints
Call Contraintes.AddMateConstraint(PlaneYZProxyForLevel0, Plane2YZProxyForLevel0, 50)
End Sub
But I got an error error.png on the line :
I also tried to edit "Test:1" in the assembly "Ensemble1.iam" when runing the code, I get the same error:
I tried many other method to get the correct proxy to put this constraint but I didn't find the good way.
Can someone help me please ?
Thank you for your help in advance !
Jérémie.
JaneFan
Hey @Anonymous,
We need get Constraints object from the sub assembly level which the constraint is created in.
Please change one line in your code then it would work:
 Sub TestSub3()
Set Contraintes = oAssemblyLevel1.Definition.Constraints
End Sub
Jane Fan
Inventor/Fusion QA Engineer
Hello Jane Fan,
It's work !
Thank you for your help !
Have a nice day,
Jérémie
