Connect arc end point with spline start point using vba
ThomasBeck8987
ThomasBeck8987
Dear all
With VBA I draw an arc and an spline. Now I try to connect the arcs end point with the spline start point using the following:
Call sklobe.GeometricConstraints.AddCoincident(oArc1.EndSketchPoint, oSpline1.StartSketchPoint)
But it comes up with Run-time error '5' "Invalid procedure call of argument.
If I try to connect the center point of the arc with the starting point of the spline it works!
Call sklobe.GeometricConstraints.AddCoincident(oArc1.CenterSketchPoint, oSpline1.StartSketchPoint)
I try as well with the merge command, but the same run-time error occurs.
Does anybody have a clue why this happens?
chandra.shekar.g
Autodesk Support
Autodesk Support
@ThomasBeck8987
Hoping that below suggestion in blog link would help to add Coincident constraint.
http://adndevblog.typepad.com/manufacturing/2012/05/addcoincident-with-two-sketch-points.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
