Configurator360 and GoExcel. Supported or not?
Skadborg.NTI
Skadborg.NTI
In online help for Configurator360 (http://help.autodesk.com/view/CFG360/ENU/?guid=GUID-96EA0CAA-73BB-42C2-94D8-73CC76791DC7) it says:
  • Configurator 360 does not allow the following in iLogic rules: MessageBox, MsgBox, InputBox, GoExcel, COM Excel functions
But GoExcel.TitleRow, GoExcel.FindRow and GoExcel.CurrentRowValue seems to work fine. Does the online help need an update, or should I avoid using GoExcel? I have tested with Inventor 2018.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Skadborg.NTI,
Checking with engineering team on this. I will get back to you after hearing from team.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
tolgay.hickiran
https://forums.autodesk.com/t5/configurator-360-forum/access-shared-data-files-a360/m-p/7875525
This thread might help you out.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
LukeDavenport
This post explains it all. GoExcel READ functions work fine, but you can't WRITE to an Excel file (or any other Office file I believe) because Excel is not actually installed on the C360 server machine, Autodesk use a third party library to access the contents of the Excel file non-natively.
Hope this helps.
https://forums.autodesk.com/t5/configurator-360-forum/excel-lookup-using-shared-data-file/td-p/81547...
