Component Suppression using ilogic
How can I include component suppression in the idw views? I suppress a component in the ipt or asm, but it doesn't
disappear from the drawing views. Is there a way to carry this over to the drawing?
PACDrafting
When selecting your assembly for base view, you need to select what LOD you created in your assembly.
But you can also use Design View Reps for this also. Just turn visibility off in the assembly and select your design view rep when placing base view into drawing.
