Auto-Auto-Reattach?
Auto-Auto-Reattach?
mrattray
Advisor Advisor
Auto-Auto-Reattach?
mrattray
Is it possible to auto-reattach dimensions programatically?
I have an assembly that I'm suppressing/unsuppressing parts in and my drawing dimensions keep getting orphaned. I discovered the "Preserve Orphaned Annotations" option, which keeps them from disappearing on me. I can then reattach the dimensions via the design doctor, but who wants to click the doctor 6 times for 20+ dimensions?
Mike
Mike (not Matt) Rattray
mrattray
My current plan here is a loop that itterates through each dimension and checks it's attachment status, reattaches if it needs it or deletes it if it fails reattachment.
Something like:
For Each dimension In dimensions
     If dimension.Attached = False then
           [auto-reattach line]
           If Err <> 0 Then
                dimension.Delete
                Err.Clear
Next
What I need is the auto-reattach part. I can't find anything about reattachment in the help, the object browser, or in the forums.  Is the design doctor and it's methods (pun!) not exposed?
Thnaks,
Mike
Did you resolve this?
i've got this exact problem, tried doing a recreate of the dimension, like so..
Inventor.LinearGeneralDimension lDim = d as Inventor.LinearGeneralDimension;
                    Inventor.LinearGeneralDimension newDim = sheet.DrawingDimensions.GeneralDimensions.AddLinear(d.Text.Origin, lDim.IntentOne, lDim.IntentTwo, lDim.DimensionType, lDim.ArrowheadsInside, lDim.Style, lDim.Layer);
                    newDim.Text.Color = lDim.Text.Color;
                    newDim.Text.FormattedText = lDim.Text.FormattedText;
but didn't work.
-Doug
mrattray
No I haven't been able to come up with anything along the workflow I had posted. It appears to me that the function simply isn't exposed.  I've been using a complicated and tideous work around for what I was trying to do.
Found somebody that had an idea that worked...
thought you would like to know
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/How-to-locate-orphaned-Dimensions-on-D...
-Doug
josiah.fordCEEGJ
This is a just a few years later than the original post! But for sake of anyone still wondering. Here is a full code that will auto-reattach anything possible.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim UNDO As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Auto Reattach")
For Each oDim As DrawingDimension In oDoc.ActiveSheet.DrawingDimensions
	If oDim.Attached = False
		oDoc.SelectSet.Select(oDim)
			Try
				ThisApplication.CommandManager.ControlDefinitions.Item("DLxAnnoReconnectCmd").Execute
			Catch
			End Try
		oDoc.SelectSet.Clear
Next
UNDO.End
