Component Replace
Component Replace
NachoShaw
Advisor Advisor
Component Replace
NachoShaw
Hey
i am working with a step file import so the geometry is dumb. I have to replace some parts with an identical existing component however, when i replace it the new part is repositioned elsewhere, not where where the original was positioned. Im guessing this is because its just in space somewhere.
Using code, is there a way of obtaining a parts actual location either by XYZ or maybe a matrix and then transferring that data to the new part so that the new part ends up in the same place as the original?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Martin-Winkler-Consulting
@NachoShaw
Could you upload an example step assembly?
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
NachoShaw
Hey
Yes i'll upload one on Sunday
Nacho
JhoelForshav
@NachoShaw
To get the position and rotation of an occurrence in your assembly you can use the ComponentOccurrence.Transformation property. This is a matrix. You can copy that matrix from the original part and use it when placing the new part.
